Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 08-31-2004, 05:30 PM
johnson02118 johnson02118 is offline
89 T-bird fast idle
89 Ford T-bird, 3.8L engine, no supercharger. 115,000 miles. Suddenly developed fast idle problem. Dealer claims I need a new throttle body.
Drove home 300 miles from vacation on Sunday. Car ran great. Turned car off to drop off passanger. Started ok. Turned car off to unload my luggage. Car started ok. Pulled into a parking space, and when I put the car in park, suddenly began fast idle. Approx 2,000 RPM in park. Approx 1,100 in drive.
Brought it to the dealer today. They claim I need a new throttle body. They said diagnostics checked out ok. I'm sure that dealer did not remove throttle body, external inspection only. Says internal plate stuck. Problem is that throttle body is no longer manufactured. Need to find used or rebuilt.
Also need muffler - baffles shot. Dealer and Meineke both say that obstructed muffler would not cause fast idle problem. Meineke won't replace muffler until idle corrected.
Does this sound reasonable? Any suggestions? Any recommendations for used parts dealer on line?
Thanks
Old 09-17-2004, 10:51 PM
freeclimber freeclimber is offline
You can try unsticking the throttle plate by cleaning the carbon/oil buildup inside and then using penetrating oil on the external parts. Sounds like the sticking is still pretty minor.
Old 09-18-2004, 05:38 AM
Thanks for the reply. I brought the car to a local garage, and they identified and replaced the idle air control motor - a lot cheaper and easier than finding a complete throttle body. Thanks again.
