Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-31-2004, 11:27 AM
sparkling3usus sparkling3usus is offline
codes
Can anyone tell me how to pull the codes on a 1999 dodge ram pu?
Old 08-31-2004, 02:02 PM
crazy cajun's Avatar
crazy cajun crazy cajun is offline
Re: codes
on my 98 ram you turn the key on and off 3 times then back on look at your check engine light and count how many flashs should be your code if it flashs 5 times then pause then 2 times your code is 52= (O2 sensoers) then it will pause a minute then flash another code if there is one
crazy cajun
1997 Dodge ram 1500 V-8
1980 Yamaha XS850SG Special
Old 08-31-2004, 02:40 PM
Re: codes
thank you, lemme try it and see if that works.
Old 08-31-2004, 06:12 PM
Re: codes
Nope that didn't work, anyone else know anything about codes for a 1999 dodge pu?
Old 09-02-2004, 09:42 PM
lil red lil red is offline
Re: codes
Crazy cajun is right that how they work, make sure its on, off, on, off, on, off, on
GOOD LUCK
Old 09-03-2004, 11:08 PM
pfrontin's Avatar
pfrontin pfrontin is offline
I have a '99, and it's an OBDII. Turning the key on and off doesn't seem to work; I've tried everything.
I gave up, and went down to Chief Auto Parts (Autozone). They'll let you borrow a scanner. If there's one nearby you, it's the cheapest, easiest way to get the codes.
You can buy a scanner for about $120. I started eating paper about two weeks ago....as soon as I can shit the money I'm running down to buy my own!
Good luck, if you find a way to pull the codes without the scanner, let me know.
Old 09-04-2004, 08:33 AM
Re: codes
i have always pulled the codes that away dont no why it wont work on ya'lls ???
crazy cajun
Old 09-04-2004, 12:06 PM
pfrontin's Avatar
Cajun,
Is yours an OBDII system? I'm not too familiar with the differences from year to year.
Old 09-05-2004, 08:46 AM
Re: codes
yes it has the 318 V-8 magnum in it.There should not be much diffrents between the 98 and 99
crazy cajun
Old 09-07-2004, 01:27 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: codes
http://www.allpar.com/fix/codes.html
My Mopars
