Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-07-2002, 11:47 PM
xivera's Avatar
xivera xivera is offline
sway bar concern
After seeing Dezoris sticky thread, I'm a bit concerned if my 22mm Progress rear sway bar may cause a tear in the subframe after it's installed. Would a tie bar help? Or, something?
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 02-11-2002, 12:55 AM
xivera's Avatar
upsiedaisie...
Old 02-11-2002, 02:02 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I'm not Dezoris, but I'll try to take a stab at this for you... If you remember Jaron95 from the "old" PH board, he recently got a Skunk2 rear swaybar for his '92 Si hatchback. In the box with the bar, (it's a 21mm bar) came a paper (or maybe it was an entire page in the install directions for it) that basically said it's HIGHLY recommended that you get the mounting brackets for the sway, welded to the frame of your underside once they are bolted on. The welds should theoretically prevent the subframe tear out that can happen from larger diameter bars, to the subframe. Some of the newer swaybars out there are now incorporating some sort of back-place that is supposed to reduce the likelyhood of subframe tear out, without having to get the brackets themselves welded on. But if your bar didn't come with such backplates to accompany the mounting brackets, I myself would recommend you just get the brackets welded on ALONG with being bolted on like they normally are.
Hope that helps you out.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 02-11-2002, 02:05 PM
Cali Guy
Forgot to mention above that a tiebar won't do anything (to my knowledge) that will prevent subframe tear out. The tiebar is connected completely seperate from the swaybar, so it wouldn't have any effect on tear out. The Tiebar just stiffens up the flex that can occure between the 2 lower control arm connecting points, while the sway bar actually incures weight transfers to help balance out the suspension and neutralize yaw in the car during cornering manuvers.
hessemer69 on AIM
Old 02-11-2002, 07:17 PM
xivera's Avatar
A response!?
Thank you...
Well, my Progress bar did come with a mounting plate. I need to read the instructions again. Would you believe that I haven't installed yet!? (problem: Frozen bolt) This tearing subframe is an issue that prevents me from installing it.
I think I need to call the guys at Progress also...
Old 02-11-2002, 07:30 PM
Racing Rice's Avatar
Racing Rice Racing Rice is offline
Send a message via ICQ to Racing Rice Send a message via AIM to Racing Rice
As stated earlier, to best prevent subframe tear have it welded over the factory welds since this is where most of the stress will be. A tiebar may help a very little but not much. The welding is your safest bet. Now when you say came with a mounting plate... Are you talking about a flat piece of metal that goes on the inside of you subframe above your LCA on the nut side of the bolt? If it didnt come with this flat piece then I would either get some large washers or have a thin piece custom made so that the bolts dont tear through your subframe.
Racing Rice
Cars:
'97 Civic EX, '02 Explorer Eddie Bauer, '99 Isuzu Amigo 4x4
Bikes:
'05 Suzuki DL650 Vstrom, '05 Yamaha Raptor 660R
Old 02-11-2002, 08:40 PM
xivera's Avatar
Thumbs up Ahhh... I got it!
I don't think so...
Like I said, I need to check the instructions/hardware. To be honest, I haven't seen my Progress gear for some time. They're in the garage & it's fuggin cold.
Thanx...
Old 02-11-2002, 10:29 PM
Cali Guy
Oh crap, should I worry about putting on washers with my OEM Si sway bar, I put on my DX coupe?
hessemer69 on AIM
Old 02-11-2002, 11:34 PM
xivera's Avatar
I think your safe. Isn't the Si bar less than 20mm?
Old 02-12-2002, 12:47 PM
You should be fine, but if you get bored one day if sure wouldnt hurt anything thats for sure. I dont think the SIs have any washers or anything either but I maybe wrong.
Racing Rice
Cars:
Bikes:
