Old 08-31-2004, 10:03 AM
echang echang is offline
Where's the ECU located in a 3000GT SL?
I'd like to take a look at it and see if there's anything wrong with it, thank you.
Old 08-31-2004, 11:34 AM
Hotshot8792 Hotshot8792 is offline
Re: Where's the ECU located in a 3000GT SL?
behind the radio unit. When your sitting in the drivers seat, there's a kick panel (covered in carpet) next to your right leg attached to the center console. There's a cover looking thing thats by your right knee, pop that off with a flat head screw driver, then there's a screw that you undo with a phillips head. Then, there is one more, thing holding it in place which is down by the accelerator pedal, you can just pop that out of place by pulling on it. Now you can take the kick panel off and there's the ECU. To take the ECU completely out of the car, undo the kick panel on the other side of the console in the same way is the first kick panel, then you will see the bolts holding the ECU into place.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-31-2004, 03:39 PM
Thank you very much, I always thought it's the box under the passenger seat... what's that under the passenger seat?
Old 08-31-2004, 07:33 PM
sLADe781 sLADe781 is offline
LOL I've wondered about that box like thingy under the passenger seat too. Hmm....what is that???
Old 08-31-2004, 08:59 PM
StealthModifier StealthModifier is offline
hmm, yal have a box thng under ur passenger seat??
Old 08-31-2004, 09:11 PM
ROB3000GTVR4's Avatar
ROB3000GTVR4 ROB3000GTVR4 is offline
AF Premium User
Re: Re: Where's the ECU located in a 3000GT SL?
Old 08-31-2004, 09:37 PM
the box under your passenger seat is the amplifier that goes to your stock radio system
