Old 08-30-2004, 11:08 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
EvoIII 16G @ 17-19 psi...2.25", 2.50", or 3.0" exhaust?
I have a 1997 4G63 turbo . I want an EvoIII 16G for sure . Supporting mods will include: upgraded fuel delivery and management, and MBC @ 17-19 psi, ported Evo II 02 housing, and 1G intake manifold and 1G TB.
My question: What size exhaust? 2.25", 2.5" or 3", in terms or value for the buck, for this setup? I plan to get my muffler shop to custom make one, no name brands, WITH cat (no test pipe). I race only ocassionally, and dont drive hard during regular commute, if that helps.
(Mods: have searched, found threads close to this, but not what I was looking for)
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-30-2004, 11:32 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
Re: EvoIII 16G @ 17-19 psi...2.25
well a 2.5 would be ok, but if you plan on modding it more i would go for the 3", i would be better for the long run, but then you have to get a 3" cat or a 3" high flow cat of ebay for under $100.
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 08-30-2004, 11:33 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Re: EvoIII 16G @ 17-19 psi...2.25", 2.50", or 3.0" exhaust?
go 3in, better exhaust flow = better turbo performance
Old 08-31-2004, 12:53 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
2.5 may do fine, but it's not worth saving the money from a 3.0 inch. If the shop uses press bends, like most do, you will want the 3 inch to make up for the fact that it narrows inside greatly.
Also, I wouldn't be so sure about your boost in the future. You'll tune for no knock, and that will determine the boost. You may be able to run 20+psi without knock, in which case there is no reason not to!
Old 08-31-2004, 02:10 AM
Shpyder's Avatar
Moderate moderator
3" it is then I guess, especially since pricing doesn't vary too much between the three. And I guess there's no real noticable performance difference between an unbranded 3" muffler shop exhaust and a GReddy or Apexi 3", right?
Old 08-31-2004, 02:22 AM
JoeWagon's Avatar
Banned
Only if the muffler shop uses mandrel bends, like the brand name. If not, it's value drops considerably. I would rather have a 2.5 mandrel over a 3.0 press bent, but 3.0 press isn't all that bad as a cheap upgrade from stock.
Old 08-31-2004, 02:43 AM
Shpyder's Avatar
Moderate moderator
Okay, I'll remember that for sure.
One more thing. I'll be getting a 3" then, but what size o2 housing will fit? I was looking at the evo one, and the ported one from SBR, but couldn't find a 3" one...if it indeed exists. Or do they not make 3" ones and just have custom flanges and gaskets that connect the 2.5" housing to the 3" DP.... ?
Old 08-31-2004, 12:10 PM
joemathews's Avatar
joemathews joemathews is offline
People have run 11s on 2.5 in. pressbent...but I agree that 3 in. is probably your best bet if you are having the piping press bent by a muffler shop.
1996 Eagle Talon
Old 08-31-2004, 05:42 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
i hope your not planning on puting that 1st gen intake manifold on your 2nd gen head are you? the ports on the head are so substantually small compared to the 1st gen ports so you will have a major lip... heres a picture, 2g head, 1g gasket... the gasket opening is the size of the port on a 1st gen head so thats the lip that your goin to have if you put that intake manifold on your 2nd gen head! just a thought...
Old 08-31-2004, 05:57 PM
Shpyder's Avatar
Moderate moderator
The 1G TB is 60mm right, and thats bigger than the 2G. The manifold...was it the exhaust manifold that came bigger on 1Gs or the intake manifolds? (1G heads are bigger too though right?). Holy crap I'm mad confused all of a sudden, haha.
Old 08-31-2004, 06:19 PM
JoeWagon's Avatar
Banned
He didn't mention TB, did he? He was talking about the intake manifold ports on the head. You aren't going to benefit from a large 1g intake manifold on a 2g head without porting.
2g exhaust manifold is better. 1g head/intake manifold are better. TB size.. I don't know.
Old 08-31-2004, 10:52 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
hmm... what about on my 96 RS... what should i port?
o yeah... anyone knows if the BOMZ coilover spings on ebay is any good?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 08-31-2004, 11:59 PM
kjewer1 kjewer1 is offline
AF - Advisor
1g TB is 60mm, 2g is 52mm. I'll second that its not worth going to the 1g intake mani unless you port it or do the full 1g head swap with it. You can get a sheetmetal intake for the 2g head, that might make more sense depending on the situtation (magnus).
Tehre are no off the shelf 3" o2 housings. All of the 3" downpipes start at 2.5". You can get custom tubular 3" housings (I have one) if you need it, but all but the very largest of turbine wheels is smaller than 2.5" major diameter anyway, so it doesntmake sense (mine is ~2.6 so I had to go to 3", for example)
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-01-2004, 12:29 AM
soyee7's Avatar
Banned
remember also that the WG in the evo3 has a stiff WG spring and will most likely boost creep to around 19psi, especially with a 3in ehaust setup. you should get the WG flapper mod done to the the turbo before purchasing it.
Old 09-01-2004, 12:54 AM
Shpyder's Avatar
Moderate moderator
okay. SBR and RRE do the flapper mod thing. Got it.
