Go Back   Automotive Forums Car Chat > Honda > Legend | RL
Old 08-30-2004, 09:47 PM
iamtimman iamtimman is offline
Question '88 Legend starter
Nice and simple... where is the starter located on the 88 Legend, and how difficult is it for a novice to replace?
thanks
Old 01-31-2005, 04:26 PM
Icampbell Icampbell is offline
When you open the hood don't let the hood hit your head because of the weak shocks. Anyways if you look straight down from the throttle body, you should see a blue wire which is going into the starter. The starter doesn't really stick out, so you kind of need to know what a starter in general looks like, pluse it is resting ontop of the transmission. If you can't find it, grab the positive battery cable, there might be two splitting from the connection, follow the one that goes down toward the transmission, and you will have found the starter. I think the starter only has two bolts that hold it into place, and it is a little difficult to put back into place if you don't have small hands...............good luck
