Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-30-2004, 08:23 PM
sweating_in_georgi sweating_in_georgi is offline
Question AC Blower just quit?
I have an 1990 Olds Delta 88. The Ac was working just fine (after filling it with refriderant) and 3 months later the fan started to slowly blow fst - and - slow instead on the normal speed. And today it stopped working. I think it might be a Relay...but i dont know where to find them. (If that is the problem). Does anyone have any good advice??
Re: AC Blower just quit?
And by the way...my model has the automatic climate control....
Old 09-01-2004, 09:33 PM
92-LS 92-LS is offline
check the blower module. It functions as the resistor for the auto climate control. It is square shaped and should be close to the blower motor.
Old 09-02-2004, 01:06 AM
thanks for the reply....but the strangest thing...it works??? today?
Old 09-12-2004, 04:56 PM
auto trainy auto trainy is offline
It sounds like its near the set temperature if its running in auto.
Old 09-12-2004, 09:12 PM
Re: Re: AC Blower just quit?
Thnks for the reply...but:
no...its totally dead now. I am wondering if there is anything else it could be... I checked the fuses, and the relays - they are both good. Is there anything eles that could cause the blower to stop working in the manner described above besides the motor being faulty? If not...where is the motor located? (im thinking about replcing it) - but i dont know where to start.
Old 09-12-2004, 09:14 PM
where is the blower motor??? (basically thats my main problem - im thinking every thing else except that and the motor itself has been checked out)
Old 09-13-2004, 04:47 PM
If it is like a 95,it's located directly behind the engine ,on the firewall in the middle of the car.
Old 09-13-2004, 04:49 PM
Did you check that blower module as the other post said?
Old 09-16-2004, 12:54 PM
87accordlxi 87accordlxi is offline
Send a message via ICQ to 87accordlxi Send a message via AIM to 87accordlxi Send a message via Yahoo to 87accordlxi
You may want to flush out your evaporator. It's fairly common for these cars to pick up soot from the road and clog up the evaporator. This would cause air velocity to decrease and I imagine it could burn out the blower motor of the passage is blocked.
- Joe
'99 Olds Intrigue GX - 3.8L - Black
Old 09-19-2004, 07:10 PM
Ofnarcr Ofnarcr is offline
My olda AC works but only comes outta the top and bottom vents. Nothing comes out of the middle ones. Ever. Not when i turn and mess with the controls nothing comes out. It used to.
