View Poll Results: radiator fan???
HTML 0 0%
vB code 0 0%
Voters: 0. You may not vote on this poll
Old 08-30-2004, 08:15 PM
91f-bird 91f-bird is offline
Send a message via AIM to 91f-bird
radiator fan wont start
I have replaced the fan motor and she still wont start up...doesnt look like wires are bad or fuses any suggestions about what to try or do ?????
Old 09-01-2004, 07:37 PM
Philo Philo is offline
Assuming the engine is overheating (and the fan is not switching on when it should), the next thing I would check is the temperature sensor that tells the fan to start (I don't have one of the newer TA's, but there must be a sensor that tells the fan to start when the temperature gets too high).
Old 09-01-2004, 09:27 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: radiator fan wont start
you either have a bad temp switch, (fan relay gone bad had this problem on a 91 camaro), or just a blown fuse. have you tested the fan. i always checked mine with a battery charger and 2 nails. and the fan will start up.
Old 09-02-2004, 12:48 PM
CW_racefan CW_racefan is offline
Single fan? Have you checked the fan relay? As I remember from my 90, its up on the firewall, left side along side the fuel pump relay.
Old 09-09-2004, 07:18 PM
thanks alot for the input guys im gonna try that and if u think of anything else let me know...thanks a bunch
