Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-30-2004, 08:26 PM
GTP Dad GTP Dad is offline
Pontiac Guy
95 Prelude No Start Condition
Friend of my son's just bought a used 95 Prelude with the 2.2 sohc engine. He is trying to get it running. He has fuel pressure, new wires, distributer cap and rotor, new plugs but it will not start. Checked to make sure the rotor was turning but didn't have time to do much else. Has minimal spark coming from the coil but doesn't seem to have enough to run the engine. It will fire with ether but won't run. Questions are: 1. Could coil be too weak to fire the plugs. Will check to see if timing is correct but owner stated that the car ran before the engine was pulled to work on engine compartment. 2. Could ECM have gone bad or shorted out? Any suggestions will be helpful, I can work on US makes but Honda's are not familiar to me and I don't really know where to start. Thanks in advance!
Old 08-30-2004, 10:53 PM
kkiepvvessau kkiepvvessau is offline
Send a message via AIM to kkiepvvessau Send a message via Yahoo to kkiepvvessau
Re: 95 Prelude No Start Condition
sell the car to me for 800 lol
Old 08-30-2004, 10:59 PM
dbebesi's Avatar
dbebesi dbebesi is offline
ok, i would hope you checked this... is the battery up? genrally the firstthing you check. i would imagine you did. i'd take it to a shop that can do an electical analysis. if it's a relay or something electrical, it will trace it down. it's not terrible pricey at a decent place, and it will save a lot of time and energy if it is electrical.
Old 08-30-2004, 11:54 PM
hondadude555 hondadude555 is offline
MAybe the starter is out. It happened to my 96 Lude 2.2 Sohc about 2 days ago. I replaced the starter which i got for 40$ @ a junk yard, and now it starts in a sec. Is your car a manual, because if it is, it should should start when you push the car or roll down a hill and then switch into second gear and let off the clutch and a little gas, and it should start just like that. If it doesnt, then the starter in the car is not broken. But if it starts when you do this, then you have a bad starter.
Old 08-31-2004, 06:50 AM
Pontiac Guy
The car turns over OK so the starter is good. The battery is low due to trying to start it, having it charged and used jumper cables from another vehicle to turn it over. Just wondering how to increase the spark coming from the coil. Appears to be very weak. Tried another coil but without any change. Thanks for the suggestions so far!
Old 08-31-2004, 08:12 AM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
hmmmm..... check to see if there is a broken yellow or black wire coming from the coils engine harness plug. that is what supplies power to the coil. also recheck ALL grounds. a ground can either be the easiest fix or the most pain in the ass thing to find BECAUSE it's a ground.
Old 09-05-2004, 12:58 PM
Pontiac Guy
Thanks alot for the help guys! Got it started yesterday. Funny thing about Hondas, they have two identical plugs under the hood that connect the computer to the engine. We noticed that they were improperly connected. Switched them around and the car started immediately on cranking. Runs great now!
Old 09-05-2004, 07:43 PM
good to hear.. glad to be of service
Old 09-06-2004, 10:29 AM
joellthomas joellthomas is offline
good find! wait till the main relay gets you..
