Old 08-30-2004, 07:19 PM
japanationcivic japanationcivic is offline
need help bad with b16A1 swap
ok i have a 89 civic si with a b16a1 swap and for about a year now the car has not been started...i first had to buy a new ecu (PR3) and new distributor (T22du) and new shift linkage...well when i put those parts on the car was turning over but i realized i wasn't getting any fuel...so i went and borrowed a rz0063 relay to test the fuel pump...when i plugged it in i could tell the relay was turning on but this time the engine wouldn't even crank...so i was just wondering if anyone could help me before i load up the car and take it to some garage where they will charge my life for a $5 peice...thanx for anyones help
Old 08-30-2004, 11:37 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: need help bad with b16A1 swap
Is your ecu throw'n any codes? Look at that first before anything.
Old 08-31-2004, 11:48 PM
i don't believe it is...is there any place on the internet for a free shop manual...that way i can tell what codes it is showing if any...
Old 09-01-2004, 04:15 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Online manual for 88-91 civic: http://www.binghamtonlife.com/manual/2gsm/
Code Descriptions:
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-01-2004, 07:13 PM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
pr3 uses long and short flashes long=10 and short =1
http://honda-tech.com/zerothread?id=468260
that may help if u r showing codes
