Old 08-30-2004, 04:27 PM
Bridget Bridget is offline
Several problems with 95 Camaro, HELP!
I am having several problems with my 95 Camaro. I have asked a few people for their advice and I get something different each time. I'm new to the area and am skeptical about going to ANY garage. If I had the heads up, I may be able to specify what help I need before I get taken to the cleaners (again).
First, my AC is coming out of my defrost and floorboard vents, it should be coming out of my dash vents. Before this happened (for a short time) when I accelerated and the AC was on, I would lose my air until I reached a steady speed or let off the gas, then my air would return. Now it's just blowing through the defrost and floorboard vents.
Second, my Check Engine light is on and has been for approx 2 years. The codes showed it to be the EGR. I had a used one put in but the light stayed on. They cleaned my ports, but the light is still on. The light comes on after I have been on the road for a few minutes and usually comes on when I decrease from a steady speed.
Third, my driver door is sagging. Several opinions (one being that I will need welding) have been given. My door flung backwards in a high wind and has sagged since. If opened all the way, it will catch mid way closed, then catch again right before I shut it. With a little lifting it will close.
Fourth, When I climb a steep incline my car boggs down and makes a clunk once I have reached the top. I had a used rear end put in a couple years ago.
Sounds like the best thing to do is sell it, but I love my car. Can someone please give me a place to start?
Old 08-30-2004, 05:35 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Several problems with 95 Camaro, HELP!
well the a/c deal could be a number of problems, you might want to look into getting a new logicon. the door problem sounds like you bent the brackets, i think they are spot welded in so you will need to drill them out and weld em back in...
*Better power-to-weight ratio than a C6 corvette*
Old 08-30-2004, 05:37 PM
What is a logicon?
Old 08-30-2004, 08:32 PM
the atmosphere controls. the unit that has the three knobs on it above the radio, it controls the a/c and stuff and directs the air flow. it might be bad, i dont know if thats the only thing that could be wrong though...
Old 08-30-2004, 08:46 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
aka climate control unit, mine went out in my 95 cutlass back in december.
Old 08-31-2004, 06:45 PM
ooh, in december. that's gotta suck...
Old 09-03-2004, 12:08 PM
I'll have it checked, thanks. What about the check engine light? If it's not the EGR what could it be?
Old 09-04-2004, 12:34 PM
johnz28 johnz28 is offline
you know.. I have a 94 z28 and the check engine light keeps coming on too...I went to several mechanics and they told me is nothing to worry about... that it was the EGR valve... and I already have the replace, as well as the conectors, and I just put a new LT 1 in the car and still shows for like a minute and then it comes off... and I also put a new computer in the car.. and still... I don't know what it could be... and I think is code 84 don't remeber for sure... but yeah.. what Im going to do with mine is buy the cluster blue light speedometer and just cover the check engine so it wont show anymore... again they told me is nothing... but I hate seeing my babe with a light on.. as well as most of you for sure
Old 09-04-2004, 02:06 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
think twice about covering the light, in case somethng else happens and you don't see it come on
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-04-2004, 02:19 PM
Genopsyde's Avatar
The President
Re: Re: Several problems with 95 Camaro, HELP!
that's only 1/3 of it, also the intake manifold gasket blew and the left real caliper seized up, I said "F-it" and traded the car in.
Old 09-05-2004, 09:26 AM
it has a brand new engine... and I really take good care of my car... but anyways.. that was just an Idea.. it just drive nuts to see my car with a light you know
Old 09-07-2004, 05:20 PM
If it were my logicon, would I still have the power loss only when I accelerate? Or would it be a constant blowing through the defrost and floorboards? When I accelerate I lose the A/C out of my dash until I let off the gas and then it will reroute from the defrost/floorboard to the dash vents. I had someone check my vacuum line and one fell apart in his hand. He said that battery acid ate through it. Said it didn't appear that the canister was leaking either. Not sure now. Thanks for you guys help and opinions because I have ideas to take to someone rather than just a problems.
Old 10-27-2004, 11:11 AM
jpmurphyslaw jpmurphyslaw is offline
Did you ever find the solution to your Camaro problems regarding the air vents? My camaro is beginning to experience a similar problem.
thanks,
Philip
Old 10-27-2004, 06:29 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Did anybody ever figure out the EGR problem?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 10-27-2004, 09:12 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well, the bogging is probly related to the EGR code, i forget exactly what it is, but there is something else that can set an EGR code... i think its the O2 sensors, im not 100% sure, or an IAT sensor, something like that. Any shop that is worth anything should be able to hook a tech 2 up to it, and observe the sensor data and track down what the faulty system is.
as far as the AC systems, sounds like a you possibly lost an AC actuator, thats gonna be a bitch, cus you gotta pull the dash to get to it. or at the very least the center of it, pull the radio, and al that.
your door dosnt have to be welded, it needs to be rehung. its not a big deal, go find a big guy friend, and have him lift on the edge of the door, while you loosen the bolts, this will move the door up, while he is still holding it up, retighten the bolts, when everything is tight, let him let the door down, and then trial fit it, be prepared, you might have to try this a few times before you get it right.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
