Old 08-30-2004, 05:12 PM
cowkiller6 cowkiller6 is offline
Send a message via AIM to cowkiller6
Noob ?'s
I was looking at an eclipse (97) for my first car, but have become interested in the 3000gt. I have a few ?s.
1. What years are generation 2s.
2. What are the year differences.
3. What years look similar to 97.
Old 08-30-2004, 05:23 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Noob ?'s
1st ?: 94-97 i beleive, someone correct me if i'm wrong cause i got the impression that 98 and 99 were considered 3rd gen
2nd ?: 91-93 vr4's have 300hp 305lbs tq, 94-99 have 320hp 315lbs tq
reaon being because 1st gen only produce 9psi while the rest run 11psi
3rd?: 94-99 all look basically identical exept for the 99 wing
others will add in or correct the info i've given
Old 08-30-2004, 06:04 PM
Igovert500's Avatar
blue + red light magnet
Re: Noob ?'s
This ? gets addressed at least 2 a month, probably more. There are some difference in the internals of the engines that evolved over the years. The trannys were switched from a 5spd to 6spd. The engines switched from 2 bolt mains to 4 bolt mains.
1st gen = 91-93, 2nd gen =94-99. 99s have been called teh 3rd gen due to a different front end and 3mm lifters to eliminate the infamous 'lifter tick' that plagued the earlier models. 97 had the hoop wing similar to an eclipse spoiler. Some features such as Active Aerodynamics, Active exhaust, and Electronically controlled suspension were only available for a few years, those 3 had all been ceased by 97 I believe.
Youngvr4 mentioned the difference in hp and torque, and this can easily be remedied by doing the free boost mod which takes about 2 mins.
As far as specifics, try using the search feature on this forum and finding more details on the evolving of the engine internals and such as it has been written out plenty of times.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-30-2004, 07:52 PM
Re: Noob ?'s
1.youngvr4- I love that body kit! What kind is that?
edit- I am stupid, I thought that car was a 1992 3kgt. What kind of car and body kit is that? Prolly really expensive.
2. Also, what is a price range for a 1992 ?
3. What is the gas mileage for a 1992 3kgt LS ?
4. How does insurance compare to an eclipse?
Thanks
Old 08-31-2004, 02:10 PM
thre3kgt811 thre3kgt811 is offline
Re: Re: Noob ?'s
Thanks
u gotta be more specific with ur questions. price range for a decent 92 could go from 2000 to probably 10 or 11,000. depending on what model how many miles all that stuff. gas mileage for a 92 SL is about 18 - 24 i believe but i could be wrong. and most likely the 3000gt will have higher insurance rates. how much higher i cant be positive it all depends on what model eclipse what year all that good stuff.
Old 08-31-2004, 02:33 PM
youngvr4's Avatar
STREET RACING GURU
Re: Noob ?'s
ya know for some reason, my insurance isn't high at all with that car. maybe because its age. if it wasn't for my record. my insurance would have been 220 a month
Old 08-31-2004, 03:11 PM
osok_deadeye_21 osok_deadeye_21 is offline
1st gen is 91-94 2nd is 94-99 i dont believe there is even a 3rd gen. I dont really know if he is looking for a vr4 or a base model gt. whatever you do dont get a gt base over 96 cause they downgraded the engine hp and torque.
Old 08-31-2004, 04:07 PM
Re: Noob ?'s
What car is that in your sig young ?
Old 08-31-2004, 04:10 PM
youngvr4's Avatar
STREET RACING GURU
Re: Noob ?'s
its the most powerfull vr4 recorded so far. and as you can see its beautiful
Old 08-31-2004, 04:50 PM
Re: Noob ?'s
What year is it? Do you know that bodykit name?
Old 08-31-2004, 05:55 PM
youngmanvr4 youngmanvr4 is offline
Re: Noob ?'s
Well as you can see from my name i was going to get a 97 gsx but i started looking at the 3000GT's and now i'm in love with them. My dad wont let me get the VR-4 till i'm 16 but for now i have a 95 3000GT base and i love it.
The 91-93 3000GT's have pop-up headlights. 94-99 have the type of headlights that my car has (in my sig). I might add that the 99 has alittle different style of headlight then the 94-98's do...but they are not that different. In 94 they made all VR-4 6 speeds and they also made all VR-4 have 18" wheels (94 or 95 not sure).
The pic in youngvr4 sig is a 94 GTO with Pit Road M Falcon SPL body kit, carbon fiber hood, and Drag GT wing. The paint is MSPL Gold paint. The GTO is the VR-4 in Japan. Under the hood is; Mfr Fighter M-SPL connecting rods, pistons piston rings, valvesprings, intake manifold, injectors, cam gears, spark plug wires, intercooler, clutch, stainless steel brake lines, radiator hose, oil cooler, earthing system, short shift kit, carbon drive shaft and valve cover; Nismo fuel regulator and fuel pump; Nissan throttle body; Greddy reacing spark plugs T88-38GK singel turbo, and PRofec R boost controller. If you want to know more about it just ask.
dsm97gsx is now youngmanvr4.
94 vr-4 with 58k.
Mods: K&N FIPK, HKS EVC IV, HKS boost gauge, testpipe, EGR by-passed.
Sound: Profile Chrome and Gold amplifier (200W) and (2) 10" Red Cone Sony Xplod Subs.
Coming soon: Stillen downpipe, DN rear pre-cat, Defi boost and EGT gauge's with control unit on A-pillar.
Old 08-31-2004, 07:26 PM
Re: Noob ?'s
I can't find any info or price for that bodykit. Do you have any links?
Old 08-31-2004, 08:06 PM
Re: Noob ?'s
Heres Pit Road M's site...you can find everything you need there.
http://www.pitroadm.com/PitroadM-HP-E/newframe3.htm
Just click on Orignal parts, then click Aero parts.
94 vr-4 with 58k.
Old 08-31-2004, 08:35 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Re: Noob ?'s
You're gonna get a VR-4 when you're only 16? Insane :/
Old 08-31-2004, 10:36 PM
Hotshot8792 Hotshot8792 is offline
that Pitroad M car is gonna have some competition with Matt Monet as far as quarter mile times go with his DR1000 car at dynamic racing. If he would have ran at sea level, he would have gotten a 10.3 in the quarter at only 21 psi, of course, he maxed out his 880cc injectors so he's gotta go up in fuel. I would expect him to be in the 9s pretty soon if he makes a pass at sea level. The DR1000s are capable of running well over 30lbs of boost.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
