Old 08-30-2004, 02:47 PM
TommyT36 TommyT36 is offline
Silverado 1500 won't turnover
Battery good, dash lights come on, alarms work, locks work, turn ignition and nothing happens. No clicking, no grinding, nothing!!Doesn't help to move steering wheel, push on brake. Help!
Old 08-31-2004, 01:43 AM
desertmike1 desertmike1 is offline
Re: Silverado 1500 won't turnover
Many things can cause your problem!
try moving your gear selector while attempting to start the truck (if you have a truck that is)
you might have a bad park-neutral swich?
-Mike
Old 08-31-2004, 06:02 AM
gtmud gtmud is offline
Look at your seloniod on the starter, that will keep you from starting. To check, with the starter disconnected, have a buddy hold the key in the "start" position, Check for power on the smaller wire going to your seloniod. If you have power, bad selonoid, if not look at your nuetral safety switch.
Old 08-31-2004, 11:44 AM
Thanks gtmud and mike. Appreciate the quick replies. I'll try those suggestions when I get the truck pulled off the rocks so I can get under it. I'm new to the forum and to Chevolet trucks so I appreciate the help.
Old 09-01-2004, 05:24 PM
Thanks again folks. I had a shade tree mechanic come over. He used a hammer and screwdriver to see if the starter was on a dead spot. No luck. I reminded him that there was a "starter relay" in the electrical center. Took it out, put it back in, tapped it with a hammer handle. Truck started several times. I'm going to get a spare relay to have around. Also clean all the contacts. Thanks, I'll be back, probably.
