Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-30-2004, 03:13 PM
snizzugglesmaxima snizzugglesmaxima is offline
Exclamation ECU Code 05 05
I checked my ecu codes last night and got 03 04 which I found out is for knock sensor but I also got 05 05 does anyone know what this is? It is for my 95 GXE Maxima 140,000 miles if this helps...
Old 08-30-2004, 11:08 PM
THT THT is offline
Re: ECU Code 05 05
0505 = Everything is peachy
You must have miscounted.
~THT
Some people call it an obsession; I call it my Maxima.
Old 08-31-2004, 10:51 AM
Re: Re: ECU Code 05 05
~THT
Hi I changed the knock sensor last night and this am it cut off again with no warning I do notice alot more power but this time no check engine light came on so I checked and codes 09 08 and 01 03 came up and I looked those up and it said Engine Coolant Temperature Sensor? Any idea why and how to replace that and where it is even located? I know you stated that it could be the IAC valve would you please give me advise as to how to change this and how much it may cost... I am all new to this mechanics stuff. Last night being the first thing I have ever done mechanically, but I don't mind trying...any help would is greatly appreciated. Thanks Again
Old 08-31-2004, 12:10 PM
THT THT is offline
Re: ECU Code 05 05
How to clean your IAC: http://forums.maxima.org/showpost.ph...27&postcount=2
You don't need to change it, just clean it (even cheaper )
~THT
