Old 08-30-2004, 01:34 PM
softball1972 softball1972 is offline
Exclamation 99 Suburban shakes when climbing
My 99 Suburban shakes violently when climbing- I usually have to slow down to 50-55 mph. It feels like the engine is about to drop out of the Suburban. The service engine light ALWAYS comes on when this occurs. After a day or two, the light goes off. The dealership said the pistons were probably missfiring-tested it-they work fine. No one seems to have any answers, and it has gotten worse!!!! I have read the previous posts regarding this problem, but if anyone has anything new or different- it would be greatly appreciated! Thanks
Old 08-30-2004, 03:59 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 99 Suburban shakes when climbing
probally what is happening is the valves are sticking in the guides causing your misfire and lack of power.
This usually occurs when the engine is hot and is under a load (highway speeds, climbing hills).
I would check for proper operation of the fuel injection system and the secondary ignition first, but I would say most likely the heads are going to have to come off
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-30-2004, 05:26 PM
turn_on68 turn_on68 is offline
Send a message via Yahoo to turn_on68
Our '94 did that( like it was kickin back) after a tune up and I thought it was the tyranny. Turned out one of the spark plug boots had come off a plug. One my son had done. So check all your wires and plugs also.
Old 09-02-2004, 04:00 PM
boschmann boschmann is offline
I had a '99 do that with a 5.7 engine. Tried plugs, wires, cap & rotor but the P0300 random misfire kept coming back & it would still start sputtering up long hills. I was finally told by GM to try the fuel injectors (supposed to be a fairly common failure). Not knowing which to replace @ $55 each I took off the injection connector by the throttle body, tested each with an Ohmmeter & found all read the same. So I cleaned & applied dielectric terminal grease to the connector & haven't had the problem since.
Old 09-03-2004, 01:17 AM
010175 010175 is offline
Dorp a post when you get it fix. I would like to know what was wrong. Thanks Dave
