Old 08-29-2004, 11:23 PM
studly698 studly698 is offline
d15b2 engines?
What are these types of engines are they sohc or dohc 1.5 lx? please respond!
Old 08-29-2004, 11:29 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: d15b2 engines?
sohc, lx's had the d16's though I believe, still sohc
Old 08-29-2004, 11:33 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: d15b2 engines?
nope. lx's had the d15b2 also. only the si's and ex's had d16's
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-29-2004, 11:55 PM
Forunn Daberator
Re: d15b2 engines?
ah, I was thinking of ex insted of lx. So many letters... so little differnces. well I guess the ex was completely differnt, but thats besides the point.
Old 08-30-2004, 12:10 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
The D15b2 engine is in any 88-91 Civic (sedan, hatchback, or crx) Dx or Lx
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-31-2004, 12:55 AM
bigjoe316 bigjoe316 is offline
Can you guys tell me if it would be worth it to get a custom turbo kit for the engine or just engine swap it for one of the d16's in my 90 civic hb. thanks for the advice in advance.
Old 08-31-2004, 01:17 AM
audioquattro audioquattro is offline
Re: d15b2 engines?
i would swap to d16a6 AND turbo it!
FOR SALE
Si 5 sped trans w/ low miles 100.00
SOLD
Old 08-31-2004, 03:09 PM
just change over to mpfi then turbo it. Theres a lot of work and tuning to do though if your going turbo and want to do it right. do some reading.
ZC stuff
Old 08-31-2004, 05:12 PM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
So what can I do to this d15b2 ???
Im getting a full custom exuast, and it has a cold air intake already
soon to get an mpfi swap later.. is there anything else that can be done to get some life outta this thing, or should i just get another type of engine?
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 08-31-2004, 07:01 PM
this is going to sound stupid to you guys but what is mpfi?
Old 08-31-2004, 11:37 PM
If I was to keep my stock d15b2 engine in my 90 civic hb and get the SI fuel injection system to put into it would it be worth it.If so can someone direct me to a place to buy one. thanks
Old 09-01-2004, 12:14 AM
Forunn Daberator
Re: d15b2 engines?
yeah mpfi (Si) fuel injection (multi port fuel injection) would be worth it. Check ebay and watch the classifieds here on this forum for one. You will need intake manifold, fuel rail, injectors, resistor box, distributor, ecu, and partial wiring harness (for the injectors).
Old 09-01-2004, 08:21 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: d15b2 engines?
That's prolly the best thing you can do for the lowly d15b2 engine. It isn't a bad motor (I drive the crap out of mine and it has 226K miles on it), but it is really meant as an economy engine since it has DPFI (dual-point) - fortunately, if you get the MPFI setup from an Si/EX (d16a6), you can get almost as much power out of the d15b2 as you get with the d16a6...you'll feel it with the butt dyno, but it won't be 20hp. If you don't have enough money for an engine swap, go MPFI on your d15b2...then later on, if you decide to swap a different engine in, you've already done the wiring to accept an MPFI engine.
Just remember...making your car go faster is an ongoing process..that's why they are called projects
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 12-13-2004, 12:17 AM
DevonsCRX's Avatar
DevonsCRX DevonsCRX is offline
Send a message via Yahoo to DevonsCRX
Re: Re: d15b2 engines?
I have some questions reguarding the parts needed to do an mpfi swap.
Can you add the Intake manifold to a DX engine (D15b2) without any modifications?
I recently seen a gold plated AEM one on ebay for auction and like it and was wondering if that would work after getting the other parts.
Is the distributor on an SI different from a DX model?
Does anyone have an idea what all theses parts can add up to in cost buying them used vs. new?
Thanks for your input and help
CRX_4LIFE.......15 years old....only 148 K miles and still going strong
http://profiles.yahoo.com/crx_4life
Old 12-13-2004, 10:46 AM
Forunn Daberator
Re: d15b2 engines?
yes the intake bolts on without modifications, aftermarket one would work also. You will need the throttle body witch is not mentioned above. If you buy an aftermarket manifold it wont come with any of the sensors, usually used OEM ones will come with most if not all of the sensors. The distributors are differnt because of the differnt fuel injection. You can get them all used for around $150, new would be alot, probably 4 times that.
