Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2004, 11:01 PM
OscarMeyer195 OscarMeyer195 is offline
Brake light, Oil light, Battery light - A/C does not work
While driving on the freeway with the air conditioning on, it turns off by itselft. When the air turns off the brake light, oil light, and battery light goes on, on the dash. I also notice when this happens the voltage on the battery drops to 10 volts. The voltage is usually at around 14 volts. This can last from 30 seconds or sometimes up to 5-8 minutes.
After a while all the lights go out and the air starts to work again.
This happens mostly at highway speeds.
I've checked all the fuses and haven't seen any blow ones.
The car is a 95 Rodeo, 6 cylinders.
Old 08-30-2004, 01:00 AM
krimes13 krimes13 is offline
Re: Brake light, Oil light, Battery light - A/C does not work
Classic symptoms of a failing alternator.
I'd replace before you're stranded.
Old 08-30-2004, 08:38 AM
Ramblin Fever Ramblin Fever is offline
Totally agree, this is classic for an alternator failure in the V6's.
I highly recommend against a remanufacturered alternator, when purchasing a new one. Try to find a brand-new "Isuzu" alternator, they are worth the extra $$, and they aren't cheap.
However the hassle of the remanufacturered alternator just isn't worth the headache; these trucks hate em and will eat them up FAST!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-30-2004, 10:29 PM
Alternator
Do you guys/gals have any recomendations on where or website to purchase an Isuzu alternator?
Thank you for all your help.
Old 08-31-2004, 08:54 AM
Just got myself a brand-new one, Bosch to be exact, through my "Imports Only" mechanic. Wasn't gonna have him DO the work, but I couldn't find a NEW Bosch or Isuzu alternator anywhere in this town!
My previous one had been from Checker with a "lifetime warranty" - yeah if you want to spend an hour or so every 3 months replacing them - these truck's just eat em!
But, I have to wonder how good the alternator was to begin with.
To be honest, I don't know where you can get a NEW one, Bosch or Isuzu without having to go through a mechanic shop or dealership - however, the Isuzu dealerships here in Colorado only sale refurbished Isuzu alt's. Keep in mind, however I do have the 97 Rodeo, your year may be easier to locate.
Many of things can be linked, I've learned, to a failing alternator - for the last 3-4 months, I thought this thing was in serious need of a major tune-up, despite the fact it gets one every 2yrs. The way it was running this summer, you'd swear I'd never had it serviced.
Had slight misses, only occasional true take-off power, no a/c half the time, etc.
She now runs like a bat out of again!
Don't wait as long as I did to change it out - i was very lucky this truck didn't just croke somewhere, getting less then half amps from that stupid thing.
1997 3.2L V6 Rodeo
Old 08-31-2004, 01:45 PM
WayneO13 WayneO13 is offline
I have the same problem with a 1994 Rodeo V6 but it happens when I start the car in the morning or after it sits for 4 - 5 hours. After I drive the car for 10-20 minutes the lights go out and the A/C comes on. Sometimes if I stop and restart after about 10 minutes the lights are out and A/C works. Could the alternator also be causing this problem?
Old 08-31-2004, 03:23 PM
tomlcollins tomlcollins is offline
Wayne,
If your lights are going OFF as you drive, then you're alternator is charging fine. As a matter of fact it might even be overcharging. You need to replace your battery, and you shouldn't have any more problems unless of course you are overcharging.
Old 08-31-2004, 07:13 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
this guy should have his alt. and batt. tested and not by some stupid parts house dont just replace parts untill you get it right
but I would bet that there is a problem with the alt. from the description
Old 08-31-2004, 09:32 PM
I just replaced the battery with a DieHard Gold and the same thing is happening.
Old 08-31-2004, 11:10 PM
Imagine that.
Now that you have wasted your money on something that did not need replacing get your charging system tested I bet you will find that you need an alternator.
Old 09-01-2004, 08:49 AM
Re: Re: Brake light, Oil light, Battery light - A/C does not work
Originally Posted by 2eyefishclaw
Imagine that.
Doesn't always mean he wasted his money. Sometimes they both go, or are going; which was the case for me. I too replaced my battery a good day before my alternator, however, mine were definitely both on there way out. Battery, though still obviously functioning at the time, was swelling and starting to leak acid.
So he may not have fixed the obvious problem, but he may have needed a new battery anyway, which will kill a weak alternator and/or starter.
1997 3.2L V6 Rodeo
Old 09-01-2004, 09:21 PM
but it is much cheaper to just have it tested
Old 09-03-2004, 08:35 AM
True!
1997 3.2L V6 Rodeo
Old 10-19-2004, 08:08 AM
vokia83 vokia83 is offline
My battery light, brake light, and 4wd hi light come on and the AC cuts off. Voltage stays constant @ about 13. Just replaced alt and battery and it still happens. Doesn't seem to do it nearly as much at highway speeds. Any ideas?
Old 10-19-2004, 01:26 PM
Weak alternator. I know you just replaced it, but that's what it is that's causing the issue - specially if you bought a remanufactored alt, rather then OEM Isuzu or BOSCH.
Went through this myself all summer, after having replaced both battery & alt as well - turned out to be a bad reman. alternator
These trucks do not like weak voltage, and they will eat at whatever may be slightly weak.
Check your belts as well
1997 3.2L V6 Rodeo
