Old 08-29-2004, 07:13 PM
rspecht rspecht is offline
A/C Needs Refrigerant
I seem to have a small leak in my 92 VR-4. The previous owner replaced the R12 with R134.
I purchased a can of R134 at the local parts store and the instructions indicate that I should add it to the low-side Schrader valve.
Where can I find this valve on the 92 VR-4?
Thanks
Old 08-30-2004, 05:39 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
You need some pressure gauges... its a complete setup with hoses and gauges to tell how much refrigerant you have in the system, and for other things. i recommend you just take it to a shop and let them do it. The good thing about R134 is it is less toxic than R12, and also cheaper. Way to go on the R134 switch.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
