Old 08-29-2004, 06:49 PM
blackcavi blackcavi is offline
interior neone lighting
hi i want to install 3 Neon tubes in my cavalier, one under each of the foot rests, and one in teh basck seat. But what i real need to know is i dont want to use the cigaretter light i want to wire them with a switch, how could i do this, greatly appricated.
Old 08-30-2004, 12:33 AM
Seanscho's Avatar
Seanscho Seanscho is offline
Easy, hidden
What I did with mine is to cut the back of my floor lighter (i don't know if your car is equiped) and used the power source to connect to the switch and eventually the neons... there are plenty of electrical parts to "tap into", but I'd recommend having a fuse for everything.
Old 08-30-2004, 01:17 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Re: interior neone lighting
Your car has foot rests?? I want foot rests!
Anyway, I have one in my trunk that I tapped into the trunk light, so it comes on when the trunk lid is opened. And I have two underneath the dash on either side, and I spliced those two wires together, and plug them into the cig lighter. Thats just temporary though. And likeSeanscho said, there is plenty of stuff you can tap into to get power.
MAKE ART, NOT WAR
Old 08-30-2004, 02:52 PM
cavispeedracer cavispeedracer is offline
Send a message via AIM to cavispeedracer
i have 2 under the front dash on each side and one drilled into the foot area of my backseat. I have htem hooked up to my cig light fuse and have the toggle switches under the wheel to the right drilled into my dash. to wire the car..... pull off that plastic piece on your door trim for your ground and drill a screw into that metal and have the postive go into the fuses. also have a wire running to the back neon through that plastic piece... i have it wired and you cant see any wires in my car. I'll take pics if you want but im sure you can pull it off... sorry i typed a lot, good luck and dont short circuit your car.
1996 Camaro RS
1997 Cavalier Z24 Modified
1/4 mile 15.5 at 89mph
FOR SALE!
Old 08-30-2004, 05:42 PM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
I had two under my dash and one by the foot area in my back seat and i ran a wire to the battery and to the toggle switch. had my in car neons and windshield washer nozzel lights wired to two switches the same way. If you do it that way use a fuse. I learned that lesson the hard way!
Old 08-31-2004, 12:11 AM
Sight N Sound's Avatar
Sight N Sound Sight N Sound is offline
If you plan on adding more electrical parts in the future, like guages and such I recommend buing the following. I have one in my car and its very easy to install.
http://store.summitracing.com/partde...57#largerimage
Old 09-01-2004, 04:37 PM
Re: Re: interior neone lighting
well thanks alot guys i relay appreciaedt il let you knwo how it turns out, and also do you thng if my oxygen sensors are bad not sur eif they are but my car could loose some hp feels like i have some loss of hp, i was racing a 2000 cavalier coupe and he kept up with me and hes stock, i have a 95 cavalier z24 stock. both automatic.
