Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 08-29-2004, 05:57 PM
scotts 97 scotts 97 is offline
rear window cable
I own a 2000 elantra and the left rear window just fell, I checked it out and found that the motor is fine but the cable has jumped out,If any one has had this problem I would appreciate any help you can give me.The cable still runs though the motor but just loops at the bottom it looks like should loop around a pulley I could pull the other side apart but Im still trying to get the black sealant off me
Thanks
Old 09-29-2004, 09:15 PM
Silver X Silver X is offline
Re: rear window cable
Had the same problem.Take it back to the dealership it should still be under warrenty.
They did my passenger window even though I pulled it apart.Very common problem for Hyundai
Old 10-03-2004, 07:21 PM
camase camase is offline
Thanks
Hi,I have a 2000 elantra also.I had the same problem with both rear doors.I went to the dealer and they replaced a regulator.I thing this is something like a plastic pulley.If you have less than 60,000 kmiles the dealer will do the job free.
Good luck!
