Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2004, 05:44 PM
danforth45's Avatar
danforth45 danforth45 is offline
missing under hard accel at 5K?
I have a 97 3.2. When I'm at full throttle at 5 thousand rpm it seems like the engine stops accellerating, then loses a few hundred , and then continues on accellerating. It doesn't have any other problems and I maintain the truck meticulously. has anyone ever heard of this? This is confuseing the heck out of me.
97 Rodeo 4x4 3.2 SOHC V6
191k and running strong
31x10.50 Maxxis Buckshot
Manik grille guard
100w hella drining lights
Old 08-30-2004, 08:50 AM
Ramblin Fever Ramblin Fever is offline
To be honest, I've never hit the 5K mark, so I don't know if mine would've ever done the same as yours, seeing as we have the exact same engine. And, we're both near or at the 130K mark!
For some reason I've always been very adament about keeping the RPM's to less then 4K-4,500 at most, that's usually pulling a 4K# boat through the Rockies.
But I'm curious to hear what you find out. I've always known these engine's to be rever's, and I've heard they even like it - so I'm surprized to hear this is an issue.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-30-2004, 07:36 PM
danforth45's Avatar
Re: missing under hard accel at 5K?
it not a big deal but it is noticable, I hope someone has heard of this and can give some ideas
Manik grille guard
Old 08-31-2004, 09:06 AM
Have you thought of the alternator?? Might be a stretch, but reason I'm suggesting, is I'm sure you've read my posts about my voltage issues. Though my volts read normal 95% of the time.
Well during this time, I too had a very slight miss, like the engine would cut out for the faintest of seconds. I honestly believed the spark plugs were going, though they were just changed a year ago. Took a look at them, and they're fine, but after the gremlin (reman alternator) begin to truly show a fault, and had it replaced with new. My miss has totally vanished now.
Keep searching, I'd like to know.
1997 3.2L V6 Rodeo
Old 08-31-2004, 10:57 AM
tomlcollins tomlcollins is offline
to be honest, i'm not sure if rodeo's have rev limiters....but you are explaining exactly what a rev limiter does if so. you hit a certain speed or rpm, and the computer pulls back the reins on you for a second before letting you slam it again, then pulls back the reins again and so on. anyone know if there are rev limiters on rodeos??
Old 08-31-2004, 11:55 AM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
I remember reading somewhere that the computer has a rev limiter function.
As I recall, it is set somewhere around 6500 RPM.
I'll try to confirm this when I have more time.
Dale
Old 08-31-2004, 11:57 AM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
Spark plugs possibly. I had a problem similar to this and new plugs cleared it up.
Old 08-31-2004, 07:19 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
keep pushin to 5 you may throw a rod through the side of the block that might make it run bad
Old 08-31-2004, 10:18 PM
danforth45's Avatar
i dont push it to 5k alot 2eye, yes I know that's not good for it thx for the advise, But what does it sound like to you?
Manik grille guard
Old 08-31-2004, 11:08 PM
Not Sure If Its Got A Rev Limiter On That Year Or Not Maybe One Of The Guys That Has A 97 Could Find Out For You
Old 09-01-2004, 07:20 AM
danforth45's Avatar
i know 5k is to low to be the rev limiter because the redline is about 6200. don't they normally set the rev limiter near or around the redline? I'm beginning to think its the plugs, If it is the plugs what should I get. I hear you should only use Denso, then I hear NGK is ok, what say you?
Manik grille guard
Old 09-01-2004, 07:32 AM
I'm going to reaffirm my notion of the rev limiter here. just b/c the tach redline is 6200 doesn't mean isuzu engineers want you going anywhere near it. a lot of times instrumentation is solely for looks, how else do you explain why some cars not nearly capable of going certain speeds nevertheless have speedometers with gaudy numbers (like a fiesta or something with a speedo of 150, you following me??) I've hit rev limiters many times in years past and the result is exactly what you are explaining your rodeo as doing. Now whether or not yours is set at the right limit is a different story....Anyways, if you need to replace the plugs anyway then go right ahead. Use Densos, you'll have to search for the part # yourself, sorry! I personally don't think it will solve your problem, but good luck blowin' that thing up!! Let us know if the plugs do the trick..
Old 09-01-2004, 08:43 AM
Re: Re: missing under hard accel at 5K?
It seems so many cars/trucks do have a Rev limiter, so I don't see why Isuzu wouldn't have one too.
In regards to personally testing my 97 to see if it will do the same; sorry, not me, got too much invested in this baby. Not saying you're damaging yours, b/c you're probably not if it's just a once in a while occasion - I just personally don't have the gutts to do it myself.
1997 3.2L V6 Rodeo
