Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-29-2004, 03:26 PM
pfrontin's Avatar
pfrontin pfrontin is offline
Unhappy P0 171 Error Code
99 1500, 360cid, AT, 4x4.
When the exhaust gets hot (usually on long trips) it idles very rough and the check engine light comes on. I borrowed an OBDII scanner from the local Chief Auto Parts and it returned error code P0171:
"A lean air/fuel mixture has been indicated for fuel system 1/1 by an abnormally lean correction factor"
I just tuned the truck up (cap, rotor, plugs, oil & air filters, etc.), and just had the cat replaced. The timing appears correct? (around 5 degrees advanced, but I don't have a manual so I'm guessing based on other V-8's I've owned in the past). The truck runs fine on cooler days; I just drove it 120 miles this morning- no problems.
Does anyone know exactly what this code means? Is it the front O2 sensor reading wrong, and telling the computer to compensate in the fuel mix?
Old 08-29-2004, 08:15 PM
moparmike70 moparmike70 is offline
It sounds like the heater circuit on the 1/1 O2 is bad. This may happen intermittenly, causing the computer to think the engine is running lean. I would replace the O2.
Old 08-31-2004, 01:11 AM
hundahunta hundahunta is offline
Re: P0 171 Error Code
does the vehicle have an exhaust leak!!
Old 09-03-2004, 11:02 PM
pfrontin's Avatar
No exhaust leak...just had the cat replaced, it was clogging.
