Old 08-29-2004, 01:09 PM
anthony90si anthony90si is offline
b18 dizzy
since the plugs of a si and a 92-93 teg are different. would it better to take a dizzy from a 90-91 teg (got one spare). or should i just change the plugs.
Old 08-30-2004, 11:55 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
USE THE 90-91...but you may have to modify the ears (mounting points), not sure if all 3 bolts will line up.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 08-31-2004, 03:08 AM
Re: b18 dizzy
will the one from a 92 work
thanks
Old 08-31-2004, 03:01 PM
EF_LSVtec's Avatar
No it wont
AF Bay Area Crew
Retired SOLD 1/08
Old 09-02-2004, 01:31 AM
Re: b18 dizzy
oh.... even if i change the plugs
Old 09-02-2004, 10:12 AM
EF_LSVtec's Avatar
Yes...92-93 is obd1 (apples and oranges)...If I'm not mistaken, obd1 dizzy's have the ignitor outside and a few other differences...I thought you had a spare? Wouldnt it be much easier to use that than figuring out how to rewire a different distributor?
AF Bay Area Crew
Retired SOLD 1/08
Old 09-02-2004, 10:47 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: b18 dizzy
only an obd0 dizzy will work with an obd0 ecu. You could run the obd1 92-93 dizzy if you were running an obd1 ecu. The pickup gears on the inside of the dizzy are different. They will not work. what engine do you have? If you have an si motor get an si dizzy. If you have an ls motor...get the ls dizzy.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
