Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 08-29-2004, 10:09 AM
jackrabbit2k69 jackrabbit2k69 is offline
Angry 1996 Stratus Idling problem.
I have a 1996 Dodge Stratus 2.4L with 98K miles on it. recently i got my o2 sensor, saprk plugs, spark wires, and cool pack replaced. before that i had my rear main seal and valve cover gaskets replaced. now the problem is whenever i turn on my car, it stalls. it will run as long as you have your foot on the gas. if you are just sitting, the car will not idle. instead it will just shut down.
Any ideas as to why this might happen? HELP!!!
Old 08-29-2004, 10:59 AM
Re: 1996 Stratus Idling problem.
i forgot to mention that the Check Engine light is on. Thanks again. Anh help would be greatly appreciated.
Old 08-31-2004, 01:13 AM
hundahunta hundahunta is offline
you need to check what is the code first!!. Possible a Idle Air control problem.
Old 09-02-2004, 12:12 PM
umina umina is offline
Yah, check the codes, but it sounds like they will give you an EGR failure code. I had this happen and it eventually went away. I was too cheap to replace the valve/solenoid cause its 100 bucks.
Old 09-02-2004, 07:05 PM
i had the EGR valve replaced last year.
Old 09-15-2004, 10:17 PM
shaneland shaneland is offline
http://www.stratusphere.us/forums/in...?showtopic=124
heres how to check your codes...
then post the results...
Old 10-28-2004, 08:52 AM
vincep0 vincep0 is offline
i have a 95 that was doing the same thing. the fuel pump and comptuer got replaced. it doesnt stall anymore but it shakes and shutters at idle...any other ideas?
Old 11-01-2004, 11:14 AM
GlennGillis GlennGillis is offline
It sounds to me its the crank sensor. You should check your fire in the plugs by inserting the plug into the wire and get someone to turn it over for you. if the same two on one side do not fire its either your crank sensor or your cam sensor.
