Old 08-29-2004, 10:44 AM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
REX is buzzing at me..
ok so i tossed the LS in the CRX and tried to start it but no go, i turn the key to on and a buzzer goes off down by the fuel panel, i turn to start and nothing happens, the lights dim inside the car but there's no juice goin to the starter signal wire, i tested it with a test light
i can jump the starter by putting a jumper on the post and the signal wire and the engine starts, but the engine runs at around 4000RPM as soon as it starts..
i haven't checked to see if she's throwin a code but what could be making it not turn over?
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 08-29-2004, 11:13 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: REX is buzzing at me..
I donno but are all your grounds good?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 08-29-2004, 11:42 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Check the battery and Alternator.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 08-29-2004, 04:43 PM
i can jump the starter so there's nothing draining the battery, no shorts cause I left the battery hooked up for a few nights now and it's still fully charged, i think it's something at my fuse panel, i switched a relay that was buzzing with the one from my hatch and it doesn't buzz anymore, it just doesn't crank when i turn the key to the start position.
the grounds are good, hence the starter cranking when i jump it hehe
what could cause the engine to run at such a high idle?
the CRX had a GSR engine in it and there is 3 extra wires to the ecu that i'm guessing was for vtec, are any of the ecu pinouts switched from LS to GSR?
-Josh
projects:
