Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-29-2004, 09:09 AM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Cat Converter
How do you know when you catalytic converter plugs? Will it throw the sensor and show a light? The reason I ask is because I want to take the cat off my truck. Damn thing is stealing my horsepower!
Old 08-29-2004, 08:22 PM
moparmike70 moparmike70 is offline
Catalytic converters rarely "plug" up unless your engine isn't running properly (ie. running very rich or burning oil). All the newer vehicles have an O2 sensor to monitor the converters performance so if there was a problem the check engine light would come on. The easiest way to tell if there is a problem with the converter is to take out an upstream O2 and start the engine. If there is a problem with the converter you will notice a big difference in power when you rev the engine. This may set off your check engine light but it is the easiest way to check it without a back pressure gauge.
Old 08-30-2004, 09:05 AM
LTJGWorth's Avatar
Re: Cat Converter
Thanks. My truck runs almost perfect. No check engine lights of anything like that. I was just curious. I figure it would throw the O2 sensor and turn on the light. I do want to take this converter off. How do you go around the O2 sensor?
Old 08-30-2004, 02:37 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Cat Converter
Remove converter. Put new pipes in place. Tap hole in one of the pipes so you can stick the sensor in. You're done.
My Mopars
Old 08-30-2004, 04:53 PM
LTJGWorth's Avatar
Re: Cat Converter
Nice!
Old 08-31-2004, 01:05 AM
hundahunta hundahunta is offline
Re: Cat Converter
you need to install a resistor in place of the o2 sensor...If you remove the cat and install straight pipes, you may get a converter catalyist efficiency code...It would be the same as the coverter not working... The pre o2 sensor voltage will mirror the post sensor and set a code...
Old 08-31-2004, 01:26 AM
BleedDodge's Avatar
Re: Cat Converter
That's where you take the bulb out from the "Check Engine" light area.
My Mopars
Old 08-31-2004, 04:10 PM
LTJGWorth's Avatar
Re: Cat Converter
Well lets see... does it not work if you tap the pipe and put the sensor in? Do I have to use a resistor? I'm not taking the bulb out of my check engine light. I still need that.
Old 08-31-2004, 05:10 PM
GreenlandMopar GreenlandMopar is offline
Re: Cat Converter
Ahh yea taking the bulb outta the check engine light trick hahaha i have done that oh to many times.. umm the do make low restriction cats that you can put on instead of by passing it and worring about the O2 sensor...
Old 08-31-2004, 07:54 PM
LTJGWorth's Avatar
Re: Cat Converter
I want no cat period. Even "low restriction" cats steal hp. I'll probably just figure it out myself. I'm pretty good with that stuff anyway.
Old 09-01-2004, 01:37 PM
BleedDodge's Avatar
Re: Cat Converter
All you need is the first sensor. The second one you can totally unplug and hang up in your closet. My grandfather's truck has only the first sensor tapped into the driver's side cylinder bank side, near where the cat used to be, and it's been more than 2 years now that he's had it like this, and still no codes yet. Gas mileage is good too. That truck barks!
My Mopars
Old 09-01-2004, 05:53 PM
LTJGWorth's Avatar
Re: Cat Converter
Nice.
Old 09-07-2004, 01:01 PM
TrailLeadr's Avatar
TrailLeadr TrailLeadr is offline
Thumbs up
This will depend on how your cat is constructed, but here's the basic idea.
Take the cat off the vehicle.
Get yourself a grinder with a cutoff wheel, and open 'er up.
Make a slice across the top of the cat (so it can't be seen)
peel the outer skin back, and then with extreme care, RIP IT's GUTS OUT!
Replace the chambers within the cat with a straight pipe connecting both ends of the cat.
Fold the outer skin of the cat back down, and it you have a welder,
give it a couple tacks, otherwise use a steel exhaust strap, and a couple sheet metal screws to tie it back up.
Reinstall the cat back in it's original location.
This will keep the local inspection stations from rejecting your vehicle come inspection time. (provided that your state inspects....some don't)
and sitll get you the straight through exhaust that you really want!
93 Suburban 2500
203,000 miles on engine still running like a champ!
Tranny rebuilt at 197,000
My Daughter calls it the bus, and sits in the
third row seat praying for potholes and speedbumps!
Just Horsin' Around Equine Services
http://www.JHA-Trans.com
Old 09-07-2004, 05:56 PM
LTJGWorth's Avatar
Re: Cat Converter
Nope, no inspections in good ol' Kentucky. Hell, the inspectors probably don't even have cats on their cars. I've got a 84 GMC Jimmy without cats. I ripped them off when my exaust rusted out and I put dual exaust in it's place (without the cats).
Old 09-07-2004, 07:22 PM
BleedDodge's Avatar
Re: Cat Converter
I don't blame you, I love my straightpipes too.
My Mopars
