Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-29-2004, 08:37 AM
projecta98 projecta98 is offline
hesitation+bucking when pressing gas and occasionally stalling!
I have a 1990 Camry (Automatic) and it jerks from a stop, similar to how a car jerks when someone is learning to drive a manual transmission. If I accelerate very slowly then the jerks are not felt. Once the rpm is high enough (around 2000 to 3000, I am guessing because there is no rpm gauge in the dash board or I don't know where to look) it runs fine. Same thing happens on reserve. Some time it will stall when pressing the gas and will start again immediately. It is more noticeable on wet days.
Some History:
1. About six months ago, I had similar problem (it was jerking even in idle). I replaced the spark-plug wires along with the rotor cap because I could see arcing between the wires in when hood is open. It ran fine after the replacements.
2. Few weeks ago, the problem resurfaced and I changed the plug wire and rotor cap again. It ran fine on the first day but I have the same problem again.
I think, there is a leak in the manifold because I can feel the exausht heat when getting out from driver's seat.
Could this jerking be related to this manifold leak?
Or should I change the "ignition coils"?
Any help will be appreciated.
Thanks.
Old 08-29-2004, 06:07 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: hesitation+bucking when pressing gas and occasionally stalling!
You should just give it a good old-fashioned tune-up and go from there with the problem. If the problem persists after the tune-up, then you could move on to what other things you think it could be, like your exhaust leak for example.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 08-31-2004, 04:54 PM
Vermillion Vermillion is offline
I had a problem simliar to the jerkiness and stalling on my 93. It idled very roughly and sometimes would stall while sitting still. From a complete stop it was very jerky. I cleaned the EGR valve and all has been well since then. Hope that helps!
