Old 08-29-2004, 01:14 AM
smahala1286 smahala1286 is offline
Angry Squeeking noise
My blazer is making a squeeking noise when i drive, it isnt that noticable until i drive next to a fence or something that reflects the noise back to me. What are my possibilities. Also I notice that a squeeking noise outside the car occurs when i let off my breaks could these be related? Thanks
Old 08-30-2004, 12:53 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Squeeking noise
you are close to having your brakes wear out.
You are on your indicators which squeek just before you need new pads.
Get it checked out.
Old 08-31-2004, 12:27 AM
Re: Squeeking noise
oh i thought the wear indicators only squeeked when the brakes were applied, not all the time, ill check them
Old 08-31-2004, 12:39 AM
BlazerLT's Avatar
AF -Advisor
Re: Squeeking noise
Nope, they squeak when the brakes are NOT applied.
Old 09-01-2004, 01:24 AM
Re: Squeeking noise
ok thanks for the help.
Old 09-01-2004, 05:24 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: Squeeking noise
If its not that, then the most common thing is a siezed caliper.
Old 09-01-2004, 09:52 AM
JParrott's Avatar
JParrott JParrott is offline
It might not be any of those things. My 2000 Blazer has the same problem and it's not worn out brake pads or a seized caliper. I haven't tracked the cause down yet but it's not wheel hub/bearings either. I've cleaned the rotors and applied stop squeal to the backs of the front pads but not the rear. At any rate, the noise is still present. I'll keep looking.
Old 09-01-2004, 03:01 PM
BlazerLT's Avatar
AF -Advisor
Re: Squeeking noise
It's the pads.
Are they new? How much pad depth do you have?
Old 09-01-2004, 04:22 PM
JParrott's Avatar
Re: Squeeking noise
My pads are brand new (5-7k on them). The only thing I've really considered as a cause is crappy pads. I opted for the lower priced ones instead of the ceramic pads. It might be something I'll just have to live with unless I replace with better quality before these wear out.
Old 09-01-2004, 04:34 PM
BlazerLT's Avatar
AF -Advisor
Re: Squeeking noise
check the pad depth left.
