Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-29-2004, 12:15 AM
gomer12 gomer12 is offline
problem
my coolent seems to over heat veery offten and i add new coolent and water waht could be the problem?
Old 08-29-2004, 01:34 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: problem
are you losing coolent or just overheating?
you many need to replace the ECT sensor
Old 08-29-2004, 12:18 PM
Re: problem
I just recently aquired the car from a friend and he pours random amounts of coolant and water in. would u suggest flushing the system and startin over. and i think i have a very slight drippin problem but nothing major.
thanks
Old 08-29-2004, 03:49 PM
Re: problem
you should find and repair the leak before flushing, otherwise you are just wasting money. however there are a few parts(water pump comes to mind) that flushing the system before repairing is better. but defenity have the system flushed if you are not at the proper 50/50 mix.
Old 10-27-2004, 01:18 PM
93interceptor 93interceptor is offline
Re: problem
water actually cools better than coolant, but you need enough coolant to protect the engine/radiator and from freezing. other problems could be the water pump and/or the thermostat. start with fixxing that leak, get a flush and fill, see if that helps.
