Old 08-28-2004, 09:52 PM
Brad Thompson Brad Thompson is offline
97 t&c going dead while driving...please help
my 1997 T&C keeps going dead while driving it...the RPM's go to zero, then go back up...we put a new crank sensor on and that didn't fix it...
checked fuel pump pressure and it is fine...ran codes at local automotive store; it states the baro is out of range and hex code 20 no definition found...can anyone help? does this problem sound familiar to anyone?
please email any advice or suggestions to [email protected]
Old 10-07-2004, 08:48 AM
katwoman_4life katwoman_4life is offline
Re: 97 t&c going dead while driving...please help
same problem going on with 96 and 2001 voyagers...other people have written their problem on this site, no reply yet. do you have a remote starter in your van?
Old 12-15-2004, 08:36 PM
casa01 casa01 is offline
battery terminals loose or corroded. Mine were just loose .and it fixed the problem.
Old 12-17-2004, 02:34 PM
murph7727 murph7727 is offline
did you find the problem? If not I may be able to help.
Old 02-17-2006, 05:41 PM
Aymen ACCAD Aymen ACCAD is offline
have you try to replace the engine computer?my car is chrysler voyager 1996
my freind has the same car andthe same problem, he has change a lot of things, but it has not solved the problem until he has change the engine computer.
Old 02-18-2006, 01:04 AM
moparman58 moparman58 is offline
You might want to try running the codes using the key method:
Within a period of 5 seconds, cycle the ignition key ON-OFF-ON-OFF-ON.
Count the number of times the MIL (check engine or service engine soon lamp) on the instrument panel flashes on and off. If it is not located at the bottom of the instrument cluster, then it is located in the information center on the dashboard above the instrument cluster.
The number of flashes represents the trouble code. There is a short pause between the flashes representing the 1st and 2nd digits of the code. Longer pauses are used to separate individual 2-digit trouble codes.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, then flashes 6 more times. This denotes a DTC number 46.
Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC number 55. DTC 55 will always be the last code to be displayed.
The MIL codes are listed here:
http://www.autozone.com/servlet/UiBr...0.jsp#hd1-1--1
Did you replace the cam sensor as well as the crank sensor? That can cause it to go dead also.
