Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 08-28-2004, 07:57 PM
tkd rx7 tkd rx7 is offline
Angry starting ploblems
o.k i have a 85 rx7 12a hears my prob i turn on mr car it warms up and when i drive it anywere and turn it off it wont turn back on until the next day but now it wont turn on it sounds like it whants to but nothing . i changed spark plug ,starter,msd coils,i also check the fuil line is good filter is clean. im just lost and need some serious help ?
Old 08-29-2004, 10:13 PM
RPMtuner RPMtuner is offline
Re: starting ploblems
a motor needs 3 things to run
compression
spark
and fule
first run acompression testand if that checks out then
make shure the plugs are firing you can touch the plug to any groung and turn the car over and you should be able to see spark. or you could put a inductive timing light on it and see if it flashes when you crank.
if that checks out
then you go to fule
is the pump getting power?
is the ecu sending pulses to the injectors. it is 12 volts. and you can use a test light
. your problem lies somewhere in the above
Old 08-30-2004, 08:25 PM
thanks i try looking into that
Old 08-30-2004, 11:41 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
that sux and those are nice cars
Old 08-31-2004, 08:29 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
well I had a 86 RX-7 One year ago I had the same problem when I took it to the dealship they told me that the car was flooding out and that it was a big problem for this car he had put a swich in to turn the fuel pump off what the idea was when the car flooded out you are able to dry the spark plugs out by turning the car over a few times then you turn the fuel pump back on and the car starts right up Trust me this DOES work !!!!!
I used this trick untell I rolled it over !!!!!!!!!
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 08-31-2004, 11:04 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
yea I told him in an e-mail that it was probably having a flooding problem, and after hearing your story, I'm pretty sure thats it
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 09-01-2004, 09:44 AM
Ok, so did he get it fixed yet are do you know
69" BUICK RIVIERA
1999 OLD ALERO
Old 09-01-2004, 04:15 PM
Soyo's Avatar
not a clue
Old 09-01-2004, 08:44 PM
i just realized that was the same problem with my 87 rx7 because the ex-owner told me about the switch and i didnt pay attention unill the next day it didnt turn on and i shut off the pump and cranked it and when it felt like it was gonna turn on i just turned on the pump. is there any way to fix this problem????
Old 09-01-2004, 09:15 PM
not that I know of this way works for you right
why mess with a good thing
69" BUICK RIVIERA
1999 OLD ALERO
Old 09-09-2004, 12:33 PM
thanks guys for all that info but the weird thing is when i put oil into the carb it starts up evry time but then it shut off and it wont start could it be my compression and if it is that how much comp should it have more then 150?.
Old 09-09-2004, 01:02 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Sounds like a hot start problem. How many miles on the motor? It could very well be a compression problem.
Old 09-10-2004, 12:11 PM
dont realy now motor came from a diffrent car i do now it was re buld once more then years ago. and if thats the case do i need to re buld it
