I am trying to add a slide in bracket to the headliner of my 2000 Silverado (new body style) near the windshield. Does anyone know how the headliner is attached there and how to remove it? I need to at least make a gap between the headliner and the metal roof frame so I can slide the bracket in. Thanks!
Headliner help
First off... what are you trying to make? Now.. the only things that are holding the front of your headliner in is the 2 "A" pillar trim pieces, the sunvisors ( which are only held in with T-15 torx head screws) and your console if you have one. The console will have a phillips head screw near the windshield and after taking that out you should be able to pull it down ( pull hard). Good luck.
Sure, I know how to do that...... |
I am mounting a Whelen emergency strobe light and the bracket has to slide in between the headliner and the roof beam.
Thanks for the help! I will try this tomorrow. |
Re: Headliner removal in 2000 Silverado
I got it all installed today! Looks good and was real easy. Thanks for the quick reply and your help. This is a great site!
AH.. gotcha... glad I could help!
Re: Headliner help
why the f*ck would you want an emergency strobe light in your car? what is it for?
Re: Re: Headliner help
Are the front of these headliners supposed to be glued down or something? I can't get it down. I'm working on putting in a mirror with the temp, comp, auto dim and passenger airbag display. Got it from a wrecked suburban.
Re: Re: Headliner removal in 2000 Silverado
A friend of mine in highschool had a Ford ranger. He got some mini strobes from the autoparts and rigged them up to his cigarette lighter. They were mounted in the roof of his truck. We used to go out at night, get behind a car and "pull them over;" as they thought it was a cop behind them. Lotsa fun. He later got a ticket when he mounted them to his bumper
I had a Dual dashMiser in above my rear-view mirror, but removed it and went for a stealth look...now all mine are hide-a-ways and grille.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
