Old 08-28-2004, 02:10 PM
tslawrence tslawrence is offline
check engine light is on
My check engine light came on in my Honda Accord, 1998, yesterday. It has 58,000 miles on it. Is this something that needs to be checked out by a professional?
Old 08-28-2004, 02:36 PM
hondaokie hondaokie is offline
Just take it down to AutoZone and they'll hook your car up for FREE and tell you what's wrong with it. Then go from there.
Old 08-28-2004, 06:27 PM
StealthSonic StealthSonic is offline
I'm currently having this problem too.
If your car runs fine, change oil regulary, it could be that you have bad oxygen sensors. You won't be able to pass smog check with this problem.
My engine check light came on and I narrowed the problem down to O2 sensors. I am getting them replace now. It would be cheaper if you know how to do it, otherwise mechanic would charge you about $400 to get it fixed.
http://importfan_accord.homestead.com/files/New_Page_Accord.jpg
Old 08-31-2004, 09:41 AM
es_class's Avatar
es_class es_class is offline
Re: check engine light is on
there is a way to diagnose the problem yourself. on the passenger side by the right foot there is a plastic panel. pull it off and you will see wires connected to a plastic head that resembles a connector.(it should be blue) make sure the car is off. take a piece of wire about 3-5 inches long and jump the connector.(meaning- place both ends of the wire into each of the open holes in connector---there are only two holes and you can see the metal inside the holes.) with the wire jumped or connecting both openings turn the car key on to accessories(DO NOT TURN THE CAR ON) when you do this the check engine light will blink in a series of fast short blinks and long blinks. these flashes represent trouble code numbers that will tell you why that light is on. you can pick up a haynes manual and it will have the trouble code list. get back to me and tell me what you came up with. and i will also tell you what the code is if you want once you read it. good luck
es_class
BEFORE AFTER SWEET-ZX11
Old 08-31-2004, 10:29 AM
HONDA_99 HONDA_99 is offline
if any body wants to do it yourself, you can find out for yourself here -> http://www.imagestation.com/album/?id=4288023469
es_class,
6gen Accord has its OBD2 connector on driver side above kick panel, and its not cover by anything.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 08-31-2004, 10:40 AM
es_class's Avatar
Re: Re: check engine light is on
es_class,
my fault--thought it we were talking about a 92. what does obd2 stand for?
es_class
Old 08-31-2004, 08:57 PM
if i'm not mistaking its a On Board Diagnostic verision2
