Old 08-28-2004, 01:58 PM
wako528's Avatar
wako528 wako528 is offline
Arrow Need help !!!!!!!!!!!
I have a 1992 honda civic dx i want i to in stall my car alarm i fund the wires from the Key but there are 5 1 hot (battery) 1 ACC and the other 3 i dont know please help thnx
Old 08-28-2004, 04:36 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Here is a diagram. If you are not an experience installer you should always have a map. Good luck
CIVIC 1992-1995
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHITE
IGNITION HARNESS
IGNITION 1 BLACK/YELLOW IGNITION HARNESS
IGNITION 2 YELLOW
IGNITION HARNESS
ACCESSORY/HEATER BLOWER 1 WHITE/BLACK IGNITION HARNESS
STARTER BLACK/WHITE IGNITION HARNESS
PARKING LIGHTS ( + ) RED/BLACK DRIVERS KICK PANEL BEHIND FUSE BOX
Domelight GREEN/RED DRIVERS KICK PANEL
POWER DOOR LOCK GREEN/WHITE THREE PIN PLUG BEHIND FUSE BOX
POWER DOOR UNLOCK GREEN/RED (TYPE B)
TRUNK RELEASE NA N/A
TACH SENSOR BLUE AT TACH TEST CONN
BRAKE
GREEN/WHITE AT BRAKE PEDAL BRACKET
HORN
BLUE/RED
STEERING COLUMN
FACTORY DISARM
NA
N/A
