Old 08-28-2004, 10:05 AM
andrewespo's Avatar
andrewespo andrewespo is offline
Question Tailpipes
I've taken notice of when I start my car up from being cold, Ill let it run and when I look at the back tailpipes their are two wet spots. I smelled the liquid and it dose'nt seem to be gas it only really happens when started from a cold start. Might it be condensation that builds up in the pipes and then it realeased when the exhaust pushes it out; or maybe something else? (1988 GT)
Thx for help.
Old 08-28-2004, 10:48 AM
Dr GT Dr GT is offline
Send a message via AIM to Dr GT
Re: Tailpipes
where do you live? if you live in a humid place (like florida for me, which that sometimes happens) it is condensation...everything running fine otherwise?
2003 Mustang GT
five speeeeeeeeeeeed.
flowmaster exhaust.
4.10 gears.
otherwise, boner stock.
"please don't drive faster than your guardian angel can fly."
Old 08-28-2004, 11:37 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Its perfectly normal. In fact its a good thing, telling you that your motor is running clean and normal.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 08-28-2004, 12:17 PM
andrewespo's Avatar
Re: Tailpipes
I live in New York the humidity has been relatively high this year. The car is running great otherwise.
Old 08-28-2004, 11:25 PM
wildstringer's Avatar
wildstringer wildstringer is offline
some water on start up out the exhaust is fine .In fact once a year i have a iv bottle that i hook into a vac port and when the car is hot will allow a very slow stream into the engine . it cleans the carbon of the valves and tops of the pistons.
Old 08-29-2004, 08:11 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: Tailpipes
yeah a little is fine, mine has a little come out when its hot and muggy out...
