Old 08-28-2004, 09:40 AM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
question about o2 sensors
i have a 2001 eclipse gt. it has a 3.0 6 cylinder. i was putting on headers and i damaged my after converter o2 sensor. i'm going to have to splice the wires cause i need to extend the length of the sensor. i was wondering if all odb2 (or mitisubishi) cars had the same sensor/readings as far as the o2 sensors are concerned. any info would be appriciated.
Old 09-05-2004, 04:30 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: question about o2 sensors
all o2 sensors are the same and read the same you just need to make sure you use one with the same amount of wires on it, that is if you are talking about a lambda sensor which screws in the exhaust.
sometimes these are called o2 sensors
you should be able to pick up a universal one from your local autostore they are available in 1,2,3,or 4 wire just buy one that matches yours and you will be sorted.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
