Old 08-28-2004, 08:19 AM
platanus platanus is offline
Question Losing the wheel weight (performance question)
If I change my 16" steel to 16" SSR-COMP and lose 7.5 pound on each wheel, will I feel a significant improvement on acceleration?
Someone said that losing the wheel weight really doesn't help to improve acceleration.
PS : Is ssr-c realiable? stronger than honda steel wheel?
Old 08-28-2004, 09:41 AM
HONDA_99 HONDA_99 is offline
Re: Losing the wheel weight (performance question)
here is quote from Unorthodox Racing, Unorthodox Racing produces lightweight pulleys and flywheels.
Originally Posted by Unorthodox Racing
Weight loss is the most critical factor in making, or more accurately, relesing Horsepower! Each pound of weight taken off the engines rotating assembly is worth approximately 2.7HP and the figure increases dramatically with forced induction, nitrous, VTEC and increased RPM's.
http://www.unorthodoxracing.com/faq_pulleys.html
as far of relaibility; forged alloy is very strong.
during impact alloy will not react same way as steel. under severe impact steel rim will bend, but forged alloy will crack.
it will take more force to damage forged alloy then steel rim.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 08-28-2004, 09:50 AM
SSR-C 16" has only offset of 4*100 ( Ibeileve)
is this ok for 7th gen v6?
Old 08-28-2004, 10:15 AM
i mean 4x100?
4x100 is bolt pattern, and its not for your car, its for VW/Audi.
you need 5x114.3mm or 5x4.5" bolt pattern.
and you should also try to find rims that have +45mm offset (plus/minus 2mm)
offset -> http://www.tirerack.com/wheels/tech/offset.htm
bolt pattern -> http://www.tirerack.com/wheels/tech/boltpatt.htm
