Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-28-2004, 02:12 AM
DropdHatch's Avatar
DropdHatch DropdHatch is offline
Send a message via AIM to DropdHatch
Motor Wont Start
After swapping in a d16A1 the engine wont start...
It turns over but wont start. It doesnt seem to get spark from the plugs... We pulled a spark plug and tested it and the wire is giving no spark in all 4. We got a new cap n rotor, wires, plugs. Its getting gas and cams are rotating and everything. Any ideas to as of why we wouldnt have spark? Also going from 2 to 4 injectors but seems to get fuel. Any help will be appreciated.
Live life by the gear... My cars slow so I've been in 1st for a while.
Old 08-28-2004, 10:25 PM
b16a3sol b16a3sol is offline
Re: Motor Wont Start
are you getting any CEL codes? if not, check the ignition coil to see if that is working properly. make sure all your connections are correct, and that you even have power running to your coil and distributor. you should really just do a once over on the whole ignition system to make sure that you didnt forget to connect any loose wires.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 08-28-2004, 10:31 PM
hundahunta hundahunta is offline
check power to your coil, also remove the neg wire from you coil and
put a test light to it and connect the other side of the test light to the bat pos, crank the vehicle. your test light should flash if not you will need to check the igniter, signal from comp, tdc sensor, cyl sensor and so forth..GOOD LUCK!!
Old 08-30-2004, 06:13 AM
WhiteLine Civic WhiteLine Civic is offline
me 2
I have just about the same prob. it sucks don't it
Old 08-30-2004, 01:45 PM
DropdHatch's Avatar
Ok in the wirelooming where the 3 ECU plugs are in the car if you pull it up there was one bare wire hanging out... IDK why but I took that wire and grounded it and the motor started right up. We had a successful motor swap. Then my friend cracked the oil pan . But me n my friends did it. That was the problem though.
