Old 08-27-2004, 11:50 PM
Pimpdady753 Pimpdady753 is offline
Talking the big 3 question
Ok what is it, and how do you do it. thanks
Old 08-28-2004, 01:15 PM
Abell255's Avatar
Abell255 Abell255 is offline
Send a message via AIM to Abell255
battery - to ground
engine block to ground
alt + to battery +
Old 08-28-2004, 05:23 PM
cody911911's Avatar
cody911911 cody911911 is offline
Re: the big 3 question
you basically upgrade wire size and quality as well as ensure good connections.
1st rule of drinking and driving.......you gotta have a beer.....
Old 08-28-2004, 07:19 PM
why would you ground the engine block
Old 08-29-2004, 01:09 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
cuz the alternator is grounded to the engine block .... if you don't, the alt won't work right in charging the battery.
Old 08-29-2004, 10:50 AM
thankx
Old 08-29-2004, 11:35 AM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
what about alternator(+) to battery(+) and alternator(-) if there is one, to battery(-)
THE DARKNESS!!!
an African Soup Bone Production...
Old 08-29-2004, 12:36 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
all the current leaving the alternator runs through the alt + to batt +, by upgrading that wire you reduce the resistance and the voltage drop that normally occurs there
But current has to go in a loop, and all the current leaving the alt has to go back in through the -, since the alt's ground is the engine that it's bolted to, you upgrade the engine ground and the battery ground to finish off the path.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-29-2004, 12:54 PM
Navy I.C.'s Avatar
I'm thinking since the batt and alt are both connected by a chassis ground, then it's still paralelled, only difference is to parallel the alt directly to batt(-) will give you even less resistance...right?
THE DARKNESS!!!
Old 08-29-2004, 01:23 PM
sr20de4evr's Avatar
well, right now they are in parallel, but the cabling used to ground the engine and the battery suck horribly. When you add the new wire it simply drops the resistance, even though the current is still following the same basic path.
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2004, 05:32 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
alternator (+) to battery positive first has to be changed from AC current to DC current....and alternator (-) to batery (-) is the alternator being grounded to the engine block and the engine block being grounded to the chasis and the chasis being connected to the bettery (-)
Old 08-29-2004, 08:29 PM
Navy I.C.'s Avatar
Re: Re: the big 3 question
well I thought I could ask the question to people in the know without stating the obvious. yes, I know that ac has to pass through a series of diodes to become, (a pseudo), dc current but, because the people that could answer my original question already know that, I just thought I'd leave that part out...
since you so cleared that up, I guess I know enough about the ckt now, I can re-ask my question. resistance, in this case, is directly proportional to the amount of the medium, (conductors, metal frames, car chassis, etc)...right? This is...the idea behind using a larger gauge cable to lower resistance, right? so going off of that, my question, (again), is...would not a shorter cable run, (ie. batt- to alt chassis), do a lower resistance make?
please, excuse my grammar...
THE DARKNESS!!!
Old 08-29-2004, 09:00 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
because the resistance in the chassis is going to exist no matter what, unless you run individual grounds back to the the battery on everything.
another reason for grounding the block is because spark plugs no go boom with out it.
Old 08-29-2004, 09:06 PM
Navy I.C.'s Avatar
no, no ,no. I'm not saying inturrupt any other ckts, I'm just talking about the alt...
THE DARKNESS!!!
Old 08-29-2004, 09:15 PM
sr20de4evr's Avatar
yes you could run a direct cable between the batt - and alt -, but it would really serve no purpose. I mean the alt is grounded through the engine, the engine has a much lower resistance than a puny little 4awg cable will. Upgrading the engine ground and battery ground instead will have the same effect, and it will also help out your entire electrical system, not just the alt-to-batt efficiency.
'01 Black Sentra SE
'05 Silver WRX STi
