Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-27-2004, 08:46 PM
integralover's Avatar
integralover integralover is offline
Upper Ball Joint Question
i believe my driver side upper ball joint is bad. why? it only makes a poppin' noise when i go foward or backward. my lower ball joint did it no matter what. i just replaced the CV axle and still there. is there a way that i can tell if it is the upper ball joint? and how do i remove the joint? thnx and what tools will i need?
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 08-27-2004, 11:14 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
Re: Upper Ball Joint Question
is it a poppin' noise or a clunking noise/feeling.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 08-27-2004, 11:16 PM
popping. no clunking. only does it when i backup or start from first.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-27-2004, 11:41 PM
Rating's Avatar
did you replace your cv axles yourself... or did someone else do it?
Does it do it on acceleration and deceleration?
Ive been reading on the balljoints and replacing them. Here is what I got from hayne's book.
1.) The front suspension uses two balljoints. The upper balljoint, located in the upper control arm, CAN'T BE REMOVED. If it's worn or damaged, replace the upper control arm. ( See Section 5 )
2. The lower balljoint, located in the steering knuckle, can be removed, but special tools are needed. If it's worn or damaged, remove the knuckle ( See Section 7 ) and take it to an automotive machine shop or other repair shop to have it replaced.
And thats all it saies on that subject.
Old 08-28-2004, 01:08 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
did u install any aftermarket camber kits? i installed a set of cheap dropzone camber kits and the bushing inside the camber came loose. this made the whole upper control arm slide back and forth everytime i started from a dead stop or going into reverse.
www.MEDIUMRACING.com
Old 08-28-2004, 01:29 AM
Rating's Avatar
I have Skunk 2 Camber Kit its sweet as hell.
Old 08-28-2004, 02:28 AM
i do everything myself. the noise was there before i changed the cv axle and it is still there. i also replaced the lower ball joint too. so that pretty much leaves the upper ball joint, right? and i have not done anything with my suspension yet. as far as upgrades goes. on acceleration and deceleration it does not make the noise. just from the start or when i start to backup. it only happens when i start moving the car in either direction. this is just damn annoying.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-28-2004, 03:47 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: Upper Ball Joint Question
If your upper and lower balljoints do not have any stud damage or boot damage. Then they are fine. These two damages lead to your balljoints being damaged. If it is just noisy and it bugs you, then change it. Other than that, they will still be fine. Are you sure the balljoints are the cause of the noise. If it is the balljoints, a loose castlenut will cause the noise due to extra space for movement. You definately do not want to drive around with a loose castle nut.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-28-2004, 07:35 AM
Rating's Avatar
Here are some possible things,
1.) Loose engine or transaxle mounts
2.) Worn differential pinion shaft in case.
3.) Worn driveaxle bore in differential case
4.) Worn or damaged driveaxle inbord CV Joints.
If its not any of that then I donno.
