Old 08-27-2004, 07:53 PM
BreakerZero0 BreakerZero0 is offline
Send a message via AIM to BreakerZero0 Send a message via Yahoo to BreakerZero0
3000GT and V-TECH ????
I was wondering if theres any way to put V-TECH on a VR-4
I think that would be a sick idea if you can and with twin turbo. damn sick
Old 08-27-2004, 08:24 PM
sLADe781 sLADe781 is offline
Re: 3000GT and V-TECH ????
Hmm.....if that were possible, how much HP would it be pushing do ya think? That sounds pretty tight!
Old 08-27-2004, 11:03 PM
Skyline_R32_Canada's Avatar
Skyline_R32_Canada Skyline_R32_Canada is offline
LOL well first of all i think you should start out doing a little more research knowing how its spelt VTEC sans H
Old 08-27-2004, 11:25 PM
StealthModifier StealthModifier is offline
A DOHC N/A has more HP an torque than a V-TEC ..so the twin turbos on it wont make more horsepower than a VR4.. sorry but its not a good idea
Old 08-28-2004, 12:21 AM
Hotshot8792 Hotshot8792 is offline
actually, the N/A DOHC car has something similar to Vtec already on the car. The intake manifold consists of these butterflies that are controlled by the ECU. Notice that the back of the intake manifold is curved, which is basically a second path. When your car is running low rpm's, it closes the short route, causing your air to go through the longer route increasing your torque. Then, as your rpm's increase, it moves and closes off the long route allowing the air to travel the short route giving you top end. Pretty much the same thing as vtec, just doesnt mess with your cam timing. The reason they did not put these on the VR-4s is cause the small turbos spool up quick enough to give the low end torque without it, but, a lot of VR-4 owners have been trying to figure a way out to run the N/A DOHC intake manifold on their car, its just hard to figure out how to get it to work with the ECU since it has to be hooked up to it.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
