Old 08-27-2004, 07:45 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
My speedometer is squeeking!?
This is one of the most annoying things I have ever experianced in my whole life. My speedometer squeeks really bad.
Also today, it started waving around between the speed i was going and maybe 2 or 3 mph each way left and right, it had never done this until today, maybe its just coming loose?
Am I going to have to remove the whole dash to fix this or is there an easy way to access the pointer thingy?
I love cats!!
Travis
Old 08-27-2004, 07:50 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: My speedometer is squeeking!?
Sounds like your speedo cable has come loose. Take out the gauge cluster and see if u can pop it back in. Pretty simple procedure to do.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 08-27-2004, 08:10 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
may need greasing
Old 08-27-2004, 08:51 PM
Darb 2k's Avatar
Darb 2k Darb 2k is offline
yup , same thing happened to my friend on his cavy. we installed cluster inserts and the same thing happened. all it is is both things they described. its either lose, or needs to be greased or both. wd-40 should help, i beleive
Old 08-27-2004, 09:18 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
the same thing happens to me!!! mine does exactly the same thing
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 08-28-2004, 12:09 AM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
need grease
Old 08-28-2004, 01:24 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
no no on the wd-40. Its actually a degreaser
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-28-2004, 01:28 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
the same thing happened to me, it squeaked like crazy n went up n down...
went to dealership, they had to replace the cable becaus it was all rusted out, etc, and worn out
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 08-28-2004, 10:17 PM
Shaguar47's Avatar
I found out the hard way with my throttle cable. WD-40 is not a lubricant. I repeat, not a lubricant!
Old 08-28-2004, 11:22 PM
Darb 2k's Avatar
Sorry bout suggesting the WD-40, i jsut took a shot in the dark. What would work then for future reference? im looking for a lubricant that will work good on plastics too. i usually have a hard time removing my clear corners when changing my bulbs. in the past ive used the WD-40 which works somewhat ok. thanks
'89 Civic CX
