Old 08-27-2004, 02:31 PM
irenekelle irenekelle is offline
Adding Transmission Fluid to Oil?
A friend of mine suggested adding transmission fluid to the oil to remedy a slight knocking noise in the engine of my 95 f-250. It's a Marshall 460 with about 15,000 miles on it. Is he crazy, or does this work?
Old 08-28-2004, 04:49 AM
ervinj ervinj is offline
Not quite sure I do that. Don't know what will happen to enternal gaskets,O rings. If it's ticking you hear, buy a can of Marvel mystery oil and replace a quart of oil. If it's knocking, I don't think any type of additive will help.
ervinj
Old 11-04-2004, 02:45 PM
xkikbxr xkikbxr is offline
Send a message via Yahoo to xkikbxr
Re: Adding Transmission Fluid to Oil?
Usually about 1/3 to 1/2 of a quart if tranny fluid will quiet the lifter noise in your engine but if it is knocking like you said the it a rod knock and you probably have a bad bearing.
Old 11-04-2004, 07:51 PM
PigPen5150 PigPen5150 is offline
Send a message via AIM to PigPen5150
I've done it before, but I used it to keep the oil cleaner between service intervals. About 1/2 a quart won't hurt anything.
Old 11-05-2004, 10:37 AM
ModMech's Avatar
ModMech ModMech is offline
DO NOT add ATF to you engine oil and drive it that way.
Yes, it *CAN* be used to flush an engine, or quiet noisy lifters, but ATF is a piss-poor lubricant for an engine (rods, mains, cam lobes.. all things an AT does not have). You WILL get ecessive wear on these components, I gaurantee it.
If it is a knock, ATF will do nothing for it anyway. If it is a stuck lifter, a better choice is to use a quality synthetic oil like Amsoil. Synthetics are very high detergant oils, but they protect far better than conventional oils, so it would be a win-win situation for you.
