Old 08-27-2004, 12:37 PM
nmsmith's Avatar
nmsmith nmsmith is offline
Attaching lights
How exactly do folk go about using white glue to attach lights?
I have painted the back surface silver. The lens is a round clear part which touches the silver only at the rim, and has a narrow hollow in the centre.
Should I apply white glue finely round the edge (which is awkward as the glue is thick and gummy), or fill the hollow too and hope that a 1mm thick application or so will still dry clear?
The lens is 'face down' here, with the hollow pointing upwards.
Does anyone ever paint the reverse of lenses silver, instead of painting the back wall? What difference does it make?
Nick
Old 08-27-2004, 01:12 PM
flyonthewall's Avatar
Car Mod guy
Re: Attaching lights
Apply the glue with a tooth pick to the attaching surface on the lens.
Old 08-27-2004, 01:18 PM
Tikiman's Avatar
Tikiman Tikiman is offline
If I were doing that model i wouldn't let the glue anywhere near the lens. I would either put the lens in the hole dry and then glue from the other side, or put the glue in that little square hole and the put then lens in. Using as little glue as possible of course.
In your case it shouldn't do any harm to paint the inside of the lens. I use both methods depending on the way the model is put together.
Old 08-27-2004, 01:21 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
i use testors clear parts cement, to glue in windows and any other clear parts, it works great and leaves no marks and dries super clear
Old 08-27-2004, 01:23 PM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
I would put some white clear glue in the square hole then I would put a dab on the upper rim and that is it. Use the tooth pick like Fly said and use as little as possible, you shouldn't be able to see the glue you used it will be such a small amount. Clear parts always make me nervous when gluing.
Old 08-27-2004, 01:33 PM
nmsmith's Avatar
Thanks folks. I went with nervestrikes's idea, and it has worked fine!
Thank goodness for nice round lenses to cover up my not-nice not-round hand-painted silver!
I'm pleased to hear that small parts and clear parts give other people the willies too.
~nick
Old 08-27-2004, 02:44 PM
Glad to hear it worked out, can't wait to see the finished product.
Old 08-27-2004, 05:12 PM
SHIFT_drift's Avatar
SHIFT_drift SHIFT_drift is offline
i've used the clear parts cement also, and it does work pretty well...
SHIFT_drift
complete:tamiya.180sx.custom.widebody
complete:fujimi.nissan.sileighty
complete:hasegawa.toyota.celica.1600gt
complete:fujimi.mazda.rx-7.fd3s
complete:revell.datsun.510.chop.top
in progress:57.chrysler.300c.convertible.slammed
next:tamiya.nissan.skyline.2000.gt-r
