Old 08-27-2004, 12:51 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
b20 oil pump
i might be buying a 96 se integra with a broken timing belt and many bent valves, which is cool i have a b20 with a bad oil pump waiting to go in...... so my question is why do peeps use the gsr or type r oil pumps when building b20/b20 vtec's? is it better/different oil pressure or is there another reason why i should consider the gsr/type r oil pump???
thanx...........gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-27-2004, 03:23 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: b20 oil pump
VTEC oil pumps pump out more oil to keep them rod/main bearings as well as whole motor lubed up at high RPM. It is well worth it, you can't tell the difference, but you are assured that you can rev it up higher without getting the motor starved for oil.
I personally put a VTEC z6 oil pump in my D16a6. It is a perfect bolt on affair. It should be the same on B-series.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-28-2004, 05:33 AM
91civicDXdude's Avatar
Re: b20 oil pump
B20 oil pump is the same as type R. B16A and B18C1 oil pumps are better than B18A/B, but dont flow as good as the b20 and B18C
Old 08-28-2004, 06:40 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: b20 oil pump
go dry sump, thats what Im going to do when/if I get a b16a.
Old 08-28-2004, 12:21 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: b20 oil pump
Like was previously stated, they are the same as the b18c.
Old 08-28-2004, 06:37 PM
gunnmen01's Avatar
so just buy another stock b20 oil pump then..... thanx guys....
gunnmen01
Old 08-28-2004, 10:16 PM
Re: b20 oil pump
b20 oil pump same as b18c.. I learn somthing new every day.
-2000 Civic Hatch
-1998 Lexus SC300
