Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 08-27-2004, 08:19 AM
kuneeraj kuneeraj is offline
Exclamation Speed Sensor/Odometer/Fuel Gauge
RE: 1997 Jetta GL, 2.0 AUTOMATIC, 88K miles.
The fuel gauge fluctuates, speedo works at times so does the odometer, a couple of times checklight said VSS A problem with P0501 code, replaced both VSS sensors with a little plastic gear which can be fitted from the top of tranny, no use.
My Fear: Do I have to open up the entire transmission housing to check for any bad gears inside the tranny?
Please help!
Old 08-27-2004, 12:56 PM
boschmann boschmann is offline
Re: Speed Sensor/Odometer/Fuel Gauge
I doubt the problem is inside the tranny, more likely it's the wiring or instrument cluster itelf. If you have a good multimeter & a way to lift the car's front wheels I can give you a diagnostic proceedure.
Old 08-27-2004, 01:07 PM
Re: Re: Speed Sensor/Odometer/Fuel Gauge
Hi Boschmann
I would appreciate it if you can provide me the diagnostic procedure. Thanks!
Old 08-27-2004, 06:13 PM
Well to start disconnect the VSS, turn on he ignition and connect the meter to pins #1 & #3 (outer two). You should have at least 11.5 Volts.
