Old 08-27-2004, 07:41 AM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
new b16a swap engine running like poop
We just completed a 90 jdm b16a w j1 trans swap into 90 civic hatch si. Everything is complete, no codes are flashing from the ecu. It idles pretty good but when i drive it ( put load on it) It gets to 3-4k and starts to hesitate and almost feel like it is hitting the rev limiter. IT feels like the timing could be off but it revs fine at idle. Any ideas?
the car was sitting for a while so the gas could also be bad, we put 93 in and some fuel system cleaner. I am going to start replacing small things like plug wires, cap, rotor, etc.
ecu not throwing any codes. pr3 ecu
Any help would be nice
thanks
Old 08-27-2004, 08:21 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: new b16a swap engine running like poop
fuel filter? leads???? timing, try them first
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 08-27-2004, 08:30 AM
SiZ's Avatar
SiZ SiZ is offline
Check your timing and make sure its right, maybe your timing belt slipped a tooth?
Did you do your own wiring?
Old 08-27-2004, 01:43 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
It wouldn't be the wiring if hes not throwing any codes.Yeh just check the timing. Changing cap, rotor , wires, and plugs would be a good idea. While your at it just change the coil also.
Old 08-27-2004, 01:48 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
hehe..... u said poop
lol
i duno, maybe vtec not kickin in??
yea i'm with everyone else tho, try a tuneup!
Old 08-27-2004, 06:42 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Re: new b16a swap engine running like poop
Yes, yes it could be. My wiring was fucked for over a year and my car was slower than a ZC powered hatch because my wiring at the distributer and ECU wasn't shielded properly. There were no codes, and everything else worked fine. (VTEC engaged) But the timing was way off and there was no explination. It took a long time before I found someone who knew wiring well enough to know what it was and fix it.
"The nympho of info, I'm fuckin' what ya heard"
Old 08-27-2004, 07:11 PM
mellowboy's Avatar
Hmm i dunno bro? I think i had the same problem what u just said...my v-tec didn't kicked in as hard as usual. So when i tried mess'n with it and the check engine light came on and off. The wire was lose. Wait nevermind it was from the ecu plug and i had re sodder the pin. I still think yours should've thrown a code or something?
Old 08-27-2004, 07:20 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
WAY NOT TRUE look at my car NO codes and running 2189 ppm on NOX reason dist. did not have sheild wire around the TDC sensor so it was miss firing. Not the only problem HIGH compression has some to do with it but I fixed the TDC wire and the ppm are down to 786 still fails but its lower.
My thought on the problem is also Timing It may be advanced on the timing belt.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 08-27-2004, 07:23 PM
mellowboy's Avatar
SO u need the shield wire just to keep it from misfiring? Well anyways i've never been in that situation so i didn't know.
Old 08-27-2004, 07:32 PM
Cjz89civic's Avatar
AF Premium User
Ya the shield keep any RF (raido freq) from getting into the wire causing the signal to not get to the ECU correctly. But since the ECU was getting the signal it didnt see a problem. Kinda shitty but thats honda.
Old 08-28-2004, 08:45 PM
well, It was the plug wires, as i thought
i changed them and it ran nice, vtec hits nice and it is insanly loud ( no exhaust, just header)
runs nice now but the idle started fluctuating
up down up down up down.
I think it is the pcv valve
Old 08-28-2004, 09:14 PM
SiZ's Avatar
SiZ SiZ is offline
Where is it going up and down to and from? Mine on 2 different B16s has went up and down and its been the fast idle control valve.. Bouncing from around 2000 - 750 like crazy.
Here:
http://www.honda-tech.com/zerothread?id=699787
