Old 08-27-2004, 01:10 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Unhappy I think I'm going to cry..
I just redid my whole head, went through and corrected the valve lash for my cam, triple checked my wires/plugs/dizzy placement, triple checked my timing, the cam gear, and crankpulley are lined up perfect, and the fucking car still won't run, it turns over and over, and sometimes let's out a chug, then i smell gas. I'm about to just call it quits and suicide, I'm almost sorry I decided to do this shit...anyone got any ideas that pop up? Please!! I don't wanna die
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 08-27-2004, 01:13 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
did u get the motor at TDC then have the rotor at the #1 spot??
all fuel lines hooked up right?
try turning it over again and hitting the gas? i dunno i'd hafta be there kinda thing
Old 08-27-2004, 01:16 AM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
Re: I think I'm going to cry..
good luck pal, don't give up now. You have come so far.
I've only just begun...
Old 08-27-2004, 01:23 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
check your main relay
Old 08-27-2004, 01:26 AM
quiXilver's Avatar
rotor for the dizzy? didn't try hitting the gas, i didn't think that really helped fuel injected cars...
B18A
Old 08-27-2004, 01:27 AM
quiXilver's Avatar
Re: Re: I think I'm going to cry..
For one how would I "check" it, and why would my main relay get screwed up? I'm almost sorry I'm asking I'm afraid of the answer..
B18A
Forunn Daberator
is the ecu putting off anything?
Old 08-27-2004, 01:29 AM
quiXilver's Avatar
not that i can tell, i don't know how to check for codes...
B18A
I'm really not sure if this is what he is talking about, but my cooling fan relay went out and turns out one of other relays were the same. So I just swapped them to see if the fan would turn on. I'm not sure if that helps any.
Old 08-27-2004, 01:30 AM
Forunn Daberator
sometimes stuff just goes out like that, at the worst times.
Old 08-27-2004, 01:31 AM
did you plug in all your sensors? Make sure they are all back, assuming you unpluged some, then take off your negative battery terminal for a half hour to reset the ECU.
Old 08-27-2004, 01:33 AM
1PhatCX's Avatar
yea, rotate ur motor over by hand with the dizzy cap off and get it to TDC and see if the rotors at the #1 spot, if its not then unbolt the dizzy and rotate the rotor 180 degrees and bolt the dizzy back in and try it again,
Old 08-27-2004, 01:34 AM
1PhatCX's Avatar
half hour!?! u pull the hazard fuse for like 5 mins or neg cable for 10
Old 08-27-2004, 01:35 AM
quiXilver's Avatar
Really, the only sesors I had to take off was the temp sens, and the other thing right next to it on the block..the map and tps stayed on the intake manifold..so i don't know what else to check...I'll see if maybe my o2 sensor got busted off, but would that not make the car run? it sounds like the timing is just waaaaay of somehow...but HOW!?@?!?!?
B18A
Forunn Daberator
to check for codes pull back the carpet on the passengers side foot well, try to start the car and see if its blinking a code ... if it is look for the codes on : http://www.binghamtonlife.com/manual/2gsm/default.htm
