Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-27-2004, 01:05 AM
hollywood3 hollywood3 is offline
VTec or no Vtec, that is the question
I have a '96 civic si, I know it it a sohc but I don't know if it has vtec or not. Where do you look to find your engine code????
Old 08-27-2004, 01:07 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: VTec or no Vtec, that is the question
Should be vtec, there is a flat plate on the engine block a little below the head and at the seam where the motor meets the tranny.
Old 09-16-2004, 10:58 AM
hh65acivic hh65acivic is offline
if you have an SI engine it should definitely be a VTEC. my 97 ex has a 1.6l 127hp vtec.
Old 09-16-2004, 12:02 PM
mahakala's Avatar
mahakala mahakala is offline
I have a '00 civic LX (Canadian version), the block doesn't say VTEC but it is a SOHC 1.6L. I would like to know what type it is so I can begin its "transformation". I don't know if it is an H, B, D etc... I am not even sure if I need to know to start the mods. Any suggestions??
Old 09-16-2004, 12:48 PM
CivicSpoon's Avatar
There is no Spoon
I believe it should be a D16y7 non-vtec, but for sure it's a D-series. There should be a flat plate on the engine block right where the motor meets the transmission, that will tell you what your engine code is for sure.
Old 09-16-2004, 12:58 PM
mahakala's Avatar
THANKS!! Found it. It is D16Y7. Is this a good thing or a bad thing?
Old 09-16-2004, 06:17 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Where do you live? In the US there was no 96 Si.
y7 = non vtec
afaik, the only sohc d series motors that were vtec are the z6 and the y8
Old 09-16-2004, 08:38 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
dont forget the vx's and hx's
Team Lonely Drivers
Old 09-16-2004, 10:22 PM
CivicSpoon's Avatar
There is no Spoon
He's fron canada so I'm assuming his Si is their version of our EX.
Old 09-16-2004, 10:33 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Its a bad thing. Swap in a better motor
Old 09-17-2004, 09:51 AM
mahakala's Avatar
Re: Re: VTec or no Vtec, that is the question
Any suggestions as to what I should swap in?
Old 09-17-2004, 09:56 AM
goofycustomz goofycustomz is offline
Cool horse power from honda
ok look, you can push a honda motor to the edge and still get more, i built a d15b engine all motor and produced 240 horsepower to the wheels, iguess its because i am a master tech and hold a degree in horse power but any ways people dont give up,
Old 09-17-2004, 10:08 AM
mellowboy's Avatar
Re: horse power from honda
You better find a way to prove that or otherwise i'm gonna call Bullshit.
Old 09-17-2004, 10:09 AM
mellowboy's Avatar
Re: Re: Re: VTec or no Vtec, that is the question
Depends on your funds and what set up you want to do. For turbo i'd love to get a b20. For all motor...i'd get a gsr motor or type r.
Old 09-17-2004, 10:52 AM
mahakala's Avatar
Re: Re: Re: Re: VTec or no Vtec, that is the question
Funds arent high and experience with this shit even lower
