Old 08-26-2004, 11:11 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
F250 towing w/5.4 engine
Has anyone used an F250 with a 5.4 in it for towing purposes?
I'm curious because I'm looking into a new (used) truck to serve as a work truck and tow vehicle. I want to know if the 3/4 ton is heavy enough to tow a gooseneck enclosed car trailer with a 3500 LB car and a healthy amount of goodies in it, and if the 5.4 has the balls for it.
I've driven my Dad's '93 F150 towing a flatbed car trailer and a 3400 lb car w/track equipment in the bed. The lil' 302/auto chugs it out, so I'm thinking a 5.4 F250 should be adequate for me....
Also, anyone know the 2000-2002 5.4 and V-10 horsepower/torque numbers? Thanks.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-27-2004, 12:10 PM
dead man walking dead man walking is offline
Re: F250 towing w/5.4 engine
well i use an f-150 with the 5.4 with a towing rating of 9500 lbs, she tows no problem, now most people drive the new one and say "it feels slow" dont worry the computer breaks in at around 1,000 miles and she gets opened up, mine not spins the 275-75-17's on a 3.55 traction loc rear end anytime i ask it to !!
Old 08-29-2004, 09:31 PM
Purerock105's Avatar
Purerock105 Purerock105 is offline
I've got to believe that a 250 would tow easy. My 150 tows
my C5(3200lbs) on a trailer just fine, and my truck wasn't really
designed for that. 5.4, but S/C. I'm rated at 5000lbs.
01' Lightning(Stock)
98' Corvette(Not Stock)
Old 08-29-2004, 09:51 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
now, the v10 gets about 1 mpg less than the 5.4 in the f250, about 12 to 13. I would go v-10 and not worry about it. if you do go 5.4, get the 4.10 rear gears or 4.30, i do not remember. Or better yet, powerstroke diesel. I have one of those, could not ask for a better truck, 18 mpg while towing.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 08-30-2004, 11:16 PM
Glamisman Glamisman is offline
I agree with the new ratios for the rear end. I put 4:10's all around (4WD) and the differance from the 3:54's to the 4:10's is remarkable. Depending on the year of the truck, you might need to buy a micro tuner to adjust the speedo for the new ratio.
Old 08-31-2004, 11:28 AM
I on the other hand would disagree with the 4.10 i had that on my last truck and wow mpg down the drain !! however with the 3.55 off the line suffers a little but i get 20+ on the express way !! if you are worried stick to a 3.73 nice middle ground
the diesel is a great option and ford just changed out of the 7.3 to a 6.8 i believe made by them from design they stole .. errr copied from us !! but its a great diesel more power then the 7.3 hp and torque and less fuel consumed and noise has dropped my a ton ! you hardly know it a diesel, down side is oil changes cost a little more, and its a little more of a hit when you buy, but if you drive a vehicle into the ground, the diesel will outlast the truck !!
Old 09-04-2004, 02:26 PM
landyacht's Avatar
landyacht landyacht is offline
Actually, the 7.3L diesel V8 was replaced with a 6.0L diesel V8.
DO NOT BUY THE THING WITH A 5.4L ENGINE!
The truck will be absolutely gutless. It's fine for flat towing, but if you have to climb hills with the trailer on it, they're so underpowered. Plus the set-up of a 5.4L V8 in the F250 is only rated to pull about 6000lbs as the engine/chassis combination can't handle much more.
Ford actually rates it higher, but realistically after you take into account the weight of fuel, people, gear, etc. you're pulling about 6000lbs max for the purposes you've described.
Get the F250, but the 6.8L V10 gas engine is about as fuel efficient in that truck as the 5.4L when it comes to F250, and the power is sooo much better. The extra investment is worth the money!
If you really want to have a good investment, go with the diesel engine. Better fuel economy than either of the gas engines and the diesel has superior power. Not to mention their built for the long term, the body will rust off before the diesel quits on you as long you look after the thing 1/2 decent.
For the purposes you're describing, an F150 with the 5.4L V8 will work if you puchase the light-duty F250 truck (looks like an F150 but has 250 on the side...basically heavier chassis to handle heavier pulling. Comes standard with the gears and everything you need to do what you've described). this is called the 7700 package on the newer F150 and is the 8800 package on the new '04 truck.
Buy the 8 foot box for fifth wheel towing. Trust me, you'll appreciate the clearance you get.
This is my recommendation as a sales representative of Ford. The other posts before mine tell you of things that will work, the set-up i've described will be the best all-round you can hope for. Especially if you really want the F250.
Good luck!
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 09-06-2004, 03:06 PM
ModMech's Avatar
ModMech ModMech is offline
In fact I have towed ~6500# with a '99 F-150 SC LWB 4x2 with the auto trans.
That's a LOT for the 4.6L, but it was OK. Would I use a 4.6L for towing this much often? NO. Once or twice per year? SURE. The new 5.4L is WAY more powerful both in torque and Hp than the old 460s of the late '70s on, so please tell me (us) how a 5.4L could NOT be up to the task of pulling even 9,000#? Because they certainly ARE when PROPERLY equipped.
Most often I find people who are "disappointed" with the towing performance of a vehicle did NOT order or purchase it with towing in mind (no tow package rated for the loads they will pull). Most commonly, I see people getting something with a class II hitch and 4-flat wiring and they really wanted to pull 3500# PLUS, and not 3500# or LESS (class II is 2000# and LOWER). They just over grossed their tow vehicle. Who's to blame? The owner. Just make SURE what you buy is RATED for the LOAD you will use it for, and everything will be ok when properly maintained.
Old 09-07-2004, 12:03 PM
landyacht's Avatar
I have towed ~6500# with a '99 F-150 SC LWB 4x2 with the auto trans, 4.6L
I've seen a guy with a 4X4 F150 and the 4.2L V6 supercab pull 10,000lbs. The truck sure isn't rated for it, and i guarantee when he hit a hill the truck wasn't going anywhere. The trucks can do it, they just aren't rated for it.
Like i said, he'd be fine on flat ground, but encounter a hill and good luck. The engine can do it, but there is a lack of power for things like passing and hill climbing in a 3/4 tonne truck with the 'small' V8 and 6000lbs on the back and a full tank of gas and 2 people and all the 'work equipment' he'll be taking.
The guy could certainly buy it, but he'd be much happier over all with the 6.8L V10 or the 6.0L V8 diesel in the 3/4 tonne, if he's bent on a 3/4 tonne. I'm suggesting the heavy 1/2 tonne truck, because with a 3500lb gooseneck trailer to pull, his tongue weight is likely going to be in the neighborhood of 500-1000lbs. That being the case, that's to much weight for the bed of a regular 1/2 tonne, it's not rated for that much, so the heavy 1/2 will be better.
Not to mention the 5.4L V8 in the heavy 1/2 will have enough power for everything because there's not as much weight to haul around in the heavy 1/2 as the 3/4 tonne, therefore better performance for all uses.
Exactly, that's what i tried to demonstrate in my last post.
Old 09-07-2004, 12:08 PM
landyacht's Avatar
Sorry for the double post, again i say if you're buying the F250 then get the V10 or the diesel. If you decide 1/2 tonne truck, then the heavy 1/2 is the way to go.
Of them all, my personal choice is the F250 with the diesel.
Old 09-07-2004, 12:17 PM
i'd agree go with the diesel, however i own an o4 f-150 with the 5.4, live in an area with lots of hills, and even have a 3.55 rear end in my truck, i aloso worked in car/truck sales for 6 years before becoming a design/engineer and design them now, the tow rating is under rated, we do this for legal reasons, i go up north with 4 guys, a 38 ft trailer, a 4 wheeler, and gear and all the goodies, and my 5.4 has never blinked once at the weight, granted the learning computer didnt break in till around 1,000 miles but now she pulls like a son of a .. well you know and she's never shifted down more then out of overdrive, that 5.4 has every bit of oomff you'll need
Old 09-08-2004, 09:08 AM
ModMech's Avatar
That long 6500#+ tow I did WAS in hill country, and even the "under powered" 4.6L handled it very well. I was impressed. As I recall, the tow rating for my truck was 6000# ball-hitch, and 7500#? 5th wheel, so I was within the limits but barely.
Given that the new 5.4Ls make over 300 HP (over 50% more than my 4.6), and the Tq difference is similar, I can't see a v-10 being that big of an improvement if any (and I do drive them both, we own over 100 Ford trucks and vans).
Unless you tow a LOT, or drive over 30,000/year, I would not even consider a diesel. But for me all that counts is the TOTAL cost of ownership, and getting the job done.
Old 09-08-2004, 11:09 AM
landyacht's Avatar
Again, i stick by my analysis of the 5.4L V8 in the 3/34 tonne truck as being a poor set-up for what is being described to me here. As far as the new 3 valve 5.4L V8 that has been put in the new 1/2 tonne, this fellow mentioned a USED vehicle.
The new F150 with the heavy payload package is plenty good for what he wants to do. I talk about all the things i talk about regarding the 3/4 tonne truck because that's what the guy originally inquired about.
The new 5.4L V8 is plenty for what he wants to do, again, but the original inquiry is for a 3/4 tonne... that has to be because of payload limitations in the 1/2 tonne, the wanting for a tougher/heavier truck, or a preference to the look of the truck.
I don't know what ya'll consider hill country, but the hills in Alberta are NOT like the hills in many places. Attempt your feat in Roger's Pass, it ain't gonna happend i'm sorry.
I'm not trying to tell you you're lying, i believe you did it, you'll notice the blurb about the guy i know with the 6 cylinder F150. The trucks can do it. But wouldn't it be good to know you have the ability to drive on any highway anywhere in North America without having to worry about powering up hills or passing on steep grades?
That's the whole point.
The new 5.4L in the 3/4 tonne is STILL weak compared to the V10 and the diesel. Having the V10 or the diesel is gonna make for a much happier owner over time as the engine fatigue and wear and tear will not be as extreme.
Isn't it better to come prepared then not?
Old 09-08-2004, 05:03 PM
playtechnical playtechnical is offline
Red face towing w f250 5.4
The most important thing no one has mentioned is that the 2005 f250 with a 5.4 or v-10 can be had with the 5 speed auto that previously was only offered with the 6.0 diesel engine. Talk about a world of difference! It also offers an integrated trailer brake controller that communicates with the anti-lock brake system on the truck.
Old 09-09-2004, 02:43 PM
landyacht's Avatar
playtechnical
You make a good point, but the 5.4L V8 is still not a gutsy enough engine for the 3/4 tonne application in my opinion.
